Can I use Chlorinated brake cleaner to clean my final drive? - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 08-21-2015, 10:45 PM Thread Starter
Year: 1986
Model: GL1200A
Send a message via AIM to skybolt58
I see this is a very old topic, but I have a rear wheel off my 86 GL1200A, and I was wondering if I could use Chlorinated brake cleaner? I have a case of the stuff, just wondering if I could use it, or do I need to get the non chlorinated?
skybolt58 is offline
post #2 of 19 (permalink) Old 08-22-2015, 12:08 AM
Originally Posted by skybolt58 View Post
I see this is a very old topic, but I have y rear wheel off my 86 GL1200A, and I was wondering if I could use Chlorinated brake cleaner? I have a case of the stuff, just wondering if I could use it, or do I need to get the non chlorinated?
This is the wrong way to do this. Start a new thread if you really want help.
And please fill in your profile.
post #3 of 19 (permalink) Old 08-22-2015, 09:32 AM
Model: 99 GL1500SE
Just a FYI I don't see mentioned on this forum.
When you pull your final drive you can move the boot cover back at the
the motor drive and gets some lube into the back side (engine side) of the U joint. Though you need to be careful because it will fall off the drive and it can be a tight fit with hands to get back on.
I find I can slip it about half way off and puts some moly lube on with a paint brush while I turn the U joint yoke.
Otherwise this contact point is a bare metal to metal contact point.
1potter1 is offline
post #4 of 19 (permalink) Old 08-22-2015, 04:26 PM
I see a moderator started a new thread for you.
What do you mean "chlorinated"?
post #5 of 19 (permalink) Old 08-22-2015, 04:45 PM
rayjoe's Avatar
I don't see how this post is related to first?
Rayjoe
rayjoe is offline
post #6 of 19 (permalink) Old 08-22-2015, 05:47 PM
Rayjoe
It isn't. He was posting to a very old final drive thread that Skybolt had dug up and posted his question to. I suggested to Skybolt that he start a new thread (post2) and that's when John got involved and did that for him...but not before 1potter1 added his post to the mix.
Did that clear things up?
And again, I believe threads more than a year old should be locked.
post #7 of 19 (permalink) Old 08-22-2015, 06:41 PM
rayjoe's Avatar
That sounds like a good idea to me too. They can still read them but they won't end up as current post.
Rayjoe
rayjoe is offline
post #8 of 19 (permalink) Old 08-22-2015, 06:46 PM
As an aside to this "old thread problem",
VS Jeff and crew are working hard to fix it so that a thread older than "1 year" will automatically be locked when it is brought back to life...
That way, a newbie can read it all they want, but will not be able to reply to it and make it surface again..... and as this thread shows, it was irrelevant to the Original Thread Topic....
post #9 of 19 (permalink) Old 08-22-2015, 08:51 PM
NVSB4's Avatar
Model: 96 GL1500SE
The last time I bought brake cleaner, the auto shop had chlorinated and non-chlorinated versions. I had to ask the same thing to the guy behind the counter. He basically said that chlorinated had a chlorine in it that might help clean a little better, but you had to be weary of the side effects like the smell and getting it on your clothes and other things that shouldn't have something like bleach on them.
It's never too late to have a happy childhood.
Red=All bikes Blue=Wings
Chris
NVSB4 is offline
post #10 of 19 (permalink) Old 08-22-2015, 09:26 PM Thread Starter
Year: 1986
Model: GL1200A
OK thanks for all the politics, but my question was never answered? I need to clean my final drive, Not my wheels! the areas where the wheel connects to the drive! chlorinated cleaner can melt some rubber and plastics, I was just wondering if there is any of that kind of material in there, IE, seals , bushings, and so on?
Final drive noise. Did I mess up. READ THIS IF YOU'RE GOING TO PULL YOUR DRIVE SHAFT! Quick Cal Goldwing Technical Forum 53 06-04-2015 10:31 PM
GL1500 final drive and drive shaft removal tutorial uploaded wingnut Goldwing Technical Forum 15 09-22-2011 04:52 AM
Replace1200 final drive With1500 final drive? TJ859 Goldwing Technical Forum 17 10-06-2010 07:36 AM
Solvent recommendation to clean splines on rear hub and final drive 4904 Goldwing Technical Forum 13 07-03-2010 09:52 AM
Want Final Drive and Drive Flange/Rear wheel for 88/89 GL1500 4evermetric For Sale/Wanted Forum 0 09-20-2007 04:58 PM
