GL1800 2008 very noisy gear change - Page 3 - Steve Saunders Goldwing Forums
post #21 of 36 (permalink) Old 09-02-2015, 08:47 PM Thread Starter
Year: 2012
Originally Posted by Bigmick View Post
Like a previous poster asked-by any chance do you have Kury Iso grips and Kury wide levers? On some wings the combination of both once the bike gets warm with the levers adjusted so its easy for the rider,the clutch doesnt totally disengage and you will get clunky shifts also. When its cold it will be fine with this issue but when it gets warm the shifts get clunky. Also if you have the stock lever is it adjusted so its easier for you to release the clutch? Also as previously posted possibly on one of the other forums you posted on. Have you checked your clutch lever bushing to see if its worn? Because if its worn badly it can cause shifting issues with the clutch lever.
s there a place where i can see or look how to check that clutch lever bushing ?
I try the shifther it self tonight ...and it seems ok to me ...I'm not a shifting guru but that shifter look ok to me
so i guess if I can look that bushing it might be a good thing
thank you
soso565 is offline
post #22 of 36 (permalink) Old 09-02-2015, 09:48 PM
Bigmick's Avatar
I would pull the pivot pin and lever and look and check to see if theres any play between the bushing and pin.
Old age is like fine wine,you just get better.
Honorary Rhino
Nassir 5
Nassir 7
Bigmick is offline
post #23 of 36 (permalink) Old 09-02-2015, 10:00 PM Thread Starter
Year: 2012
thank you i will ty that maybe tomorrow thank again
soso565 is offline
post #24 of 36 (permalink) Old 09-02-2015, 10:19 PM
This picture is of a 1200 but it's the same bushing, if it looks oval it's worn.
Ken Bergen is online now
post #25 of 36 (permalink) Old 09-02-2015, 10:20 PM Thread Starter
Year: 2012
really and just that can cause all that clunk noise ?....i will look that tomorrow thank you
soso565 is offline
post #26 of 36 (permalink) Old 09-02-2015, 10:30 PM
I doubt that is your problem if there is one but the bushing was mentioned and most think of the pivot bushing when looking for it.
post #27 of 36 (permalink) Old 09-03-2015, 06:26 AM Thread Starter
Year: 2012
quick update****
I change the oil "again"
I now run Rotella T5 10W-30
first runs was already much better regarding the rough and noisy shifting.
when I have dump the oil ...sadly there was few metal grind tiny piece in my pan .....
PS I will still look and lubricate le clutch lever and the shifther tomorrow after work ...I will post something friday evening
soso565 is offline
post #28 of 36 (permalink) Old 09-03-2015, 06:33 AM
That don't look good. Will a magnet pick those up and can you gather them up and clean them for a better look?
The problem is not the clutch if it doesn't creep at a stop or isn't hard to get in or out of neutral.
post #29 of 36 (permalink) Old 09-03-2015, 07:01 AM Thread Starter
Year: 2012
here few closeup pictures of the biggest particles that i found in my pan after dumping the oil
about magnet ....i will have to confirm that in few hrs ...hang on
about neutral few example:
when i ride and stop at a light in gear # 4 ...I can go down to gear #2 easily , to go from 2 to 1 I need to release the clutch a little and barely push the bike back and forward and then it goes to 1 . after it quiet easy from gear # 1 to go neutral
when I ride and proceeding to stop at a light I can easily go from 5 to 4 to 3 to 2 to either neutral or 1 during the deceleration until full stop
PS
I'm french and i might be confuse between clutch term .
when I press the clutch lever toward the handle , I call it engaging the clutch
when i don't touch the clutch lever I call that the clutch is not engage
from what i read im not using the right term at the right place ( engaging and disengage )
_____________________________
soso565 is offline
post #30 of 36 (permalink) Old 09-03-2015, 07:24 AM
jobe05's Avatar
Model: 1500 & 1800
Are those chunks metal? From the picture they almost look like carbon. If it's metal you have a serious issue.
Honorary Rhino.......
jobe05 is offline
GL1500 Noisy 4th gear Lindeman Goldwing Technical Forum 11 03-17-2012 08:27 AM
Rough gear change, GL1800 soso565 Goldwing Technical Forum 6 09-28-2011 08:30 AM
Noisy gear sound jurasic Goldwing Technical Forum 8 05-04-2011 01:35 PM
GL1800 Gear Differential leaking after tire change ARTIE_24 Goldwing Technical Forum 7 04-14-2010 12:42 PM
5th gear is noisy, 1-4 are quiet and strong Bro D Goldwing Technical Forum 11 10-09-2008 01:13 PM
