GL1800 2008 very noisy gear change - Page 4 - Steve Saunders Goldwing Forums
post #31 of 36 (permalink) Old 09-03-2015, 07:51 AM
Originally Posted by soso565 View Post
here few closeup pictures of the biggest particles that i found in my pan after dumping the oil
about magnet ....i will have to confirm that in few hrs ...hang on
about neutral few example:
when i ride and stop at a light in gear # 4 ...I can go down to gear #2 easily , to go from 2 to 1 I need to release the clutch a little and barely push the bike back and forward and then it goes to 1 . after it quiet easy from gear # 1 to go neutral
when I ride and proceeding to stop at a light I can easily go from 5 to 4 to 3 to 2 to either neutral or 1 during the deceleration until full stop
PS
I'm french and i might be confuse between clutch term .
when I press the clutch lever toward the handle , I call it engaging the clutch
when i don't touch the clutch lever I call that the clutch is not engage
from what i read im not using the right term at the right place ( engaging and disengage )
_____________________________
That is incorrect, most get that wrong, has nothing to do with being french.
I agree, that does look like carbon pieces.
post #32 of 36 (permalink) Old 09-03-2015, 10:00 AM Thread Starter
Year: 2012
Originally Posted by jobe05 View Post
Are those chunks metal? From the picture they almost look like carbon. If it's metal you have a serious issue.
i had a closer look at those small piece
all of those was carbon yes
the is 4 small piece that i was not able to crush between my finger but the are not metalic
soso565 is offline
post #33 of 36 (permalink) Old 10-06-2015, 06:02 AM
Peppi-Le-Pew's Avatar
Year: 2012
Model: 2012 Blue GL1800 Level 3
Is there a chance that the debris fell from the exterior crankcase area when removing the filter and drain plug? I don't know what Honda uses for clutch material so it could be clutch. Carbon clutches in my experience tend to become smaller particles when flaking of the plates. I see it all the time in GM transmissions. Honda car transmissions have similar tendencies when the torque converter so often detonates from lack of hold off pressure. I would have the samples analyzed. I would change the oil immediately and also have it analyzed. If the clutch or engine has a problem your warranty will cover it. Better to drop the bike in the dealers lap during cold weather. They tend to be slower and more eager to do warranty work. The tech will be a little more patient since there is not much else to go onto when he finishes. It can be difficult to find a competent person to diagnose and be honest and upfront about the actual problem. Remember the dealer is working for Honda, and not you.
Peppi-Le-Pew is offline
post #34 of 36 (permalink) Old 10-06-2015, 07:51 AM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
Although I have little faith in "real" dealer" repairs, other than simple service items, I don't agree they "work" for Honda! Someone purchased a franchise and is trying to make money. Therefore most desire to keep their customers happy.
Having said that, the dealer is pretty much at the mercy of Honda, for warranty coverage, especially if the rep shows up for a review!
tfdeputydawg is online now
post #35 of 36 (permalink) Old 10-06-2015, 08:28 PM
Year: 2012
So it would seem they are working for us. Yes, they are working on our vehicle. Dealers repair what Honda and the tech rep approves. Honda has reined in their warranty repair costs. They even took away the tech reps wing to cut expenses. They used to get a new one every year. Or so i'm told. I was told by three people (tech rep included) that my washing machine sound coming from the alternator drive gears was normal, "it sounds like a goldwing to me". My persistence got the defect acknowledged and repaired. My 2012 now sounds like a normal wing. Honda wants to satisfy us so they more often than not go over and above to make us happy. Honda just last year replaced a 2002 frame under warranty for a fellow local chapter member. The only way that happened was mother Honda ponied up the frame and paid the labor. Dealers work for Honda when warranty dollars are being spent.
post #36 of 36 (permalink) Old 10-07-2015, 01:46 PM
Pastot's Avatar
The chunks appear to be small rocks or pebbles that one collects in oily spots and crevices. They could have been knocked loose from the bottom of the bike or even fell into the case during an oil change and sat there until drained out. I'd try to crush one and inspect it closer if successful, if it turns to sand you know its not part of your engine.
As for the down shift to 1st from neutral, mine has refused a few times unless I pushed the bike forward or backward a bit; completing the downshift when you are still moving very slowly prevents being left in neutral. I find it happens to me but rarely and only when I'm absolutely stopped completely.
Tom, in Mountain Home, Idaho
2002 GL1800 (Illusion Red) Non-ABS, 128k miles
Retired Air Force
"Audentes Fortuna Juvat"
Pastot is offline
GL1500 Noisy 4th gear Lindeman Goldwing Technical Forum 11 03-17-2012 08:27 AM
Rough gear change, GL1800 soso565 Goldwing Technical Forum 6 09-28-2011 08:30 AM
Noisy gear sound jurasic Goldwing Technical Forum 8 05-04-2011 01:35 PM
GL1800 Gear Differential leaking after tire change ARTIE_24 Goldwing Technical Forum 7 04-14-2010 12:42 PM
5th gear is noisy, 1-4 are quiet and strong Bro D Goldwing Technical Forum 11 10-09-2008 01:13 PM
