1998 GL1500 died on road - Page 3 - Steve Saunders Goldwing Forums
post #21 of 53 (permalink) Old 10-07-2015, 06:34 PM
Originally Posted by whitewingguy View Post
How do I bypass kill switch?
Take the 3 ( I think) screws out of the bottom of the switch housing and lift the top up. The wires are held on the switch with screws, put both wires under 1 screw.
post #22 of 53 (permalink) Old 10-07-2015, 06:36 PM
I am reading the manual and it says to check starter relay A on left side of battery.mi don't have one
I do have relay B.
Any idea why it is saying this?
Probably an aftermarket manual?
post #23 of 53 (permalink) Old 10-07-2015, 06:38 PM
As this thread has nothing to do with "Trikes, Trailers or Sidecars" but is about the underlying motorcycle perhaps it should be moved to the "Goldwing Technical Forum".
In my humble opinion this is a perfect example of why sub-forums are not a good thing.
Yer right, I just assumed it was a trike but it doesn't matter, it's a technical issue with the motorcycle.
post #24 of 53 (permalink) Old 10-07-2015, 06:40 PM Thread Starter
Model: 1998 GL 1500 SE
Checked relays continuity ok
"Today well Lived, Takes care of the days yet to come"
"So let\'s ride"
Steve
whitewingguy is offline
post #25 of 53 (permalink) Old 10-07-2015, 06:42 PM Thread Starter
I thought I was on the tech forum
Duh!
"So let\'s ride"
Steve
post #26 of 53 (permalink) Old 10-07-2015, 07:29 PM
Model: Gl se
When checking wiring it is best to push the wires towards connections rather than pulling them. I see people pulling on harnesses and it only makes a fault harder to find.
H20loo is offline
post #27 of 53 (permalink) Old 10-07-2015, 07:50 PM
Bellboy40's Avatar
Year: 2000 & 1994
Some other findings
The reverse light does not go on.
When I pull the reverse all the way back the headlights go out. But no reverse light. Still no starter action when I press starter button
Just for your information, the reverse light on the 1500 will not come on if the engine is not running.
Larry
-- Albert Einstein
Bellboy40 is offline
post #28 of 53 (permalink) Old 10-07-2015, 08:19 PM
96 and up I believe the kill switch does kill the starter.
Kill switch kills the starter on my '97.
Kill switch only kills the ignition on my '96 so it looks like it's '97 and up.
spiralout is offline
post #29 of 53 (permalink) Old 10-08-2015, 07:51 AM
Year: 2008
"I checked the voltage from bat to the 2- terminals on starter selonoid, no power on either the red or blue.
I am baffled."
Is this with the switch on and starter button pushed? If so back up from the starter to the first relay, test both sides of relay with switch on and starter button pushed. Where are you putting the ground probe of the voltmeter? Try both the frame and then the battery post (not - cable). Sorry, I don't have a 1500 manual but I'm sure someone will come along and help with the relay names and locations to test. Good luck.
Charlie
flylow is offline
post #30 of 53 (permalink) Old 10-09-2015, 09:09 AM
Model: 1999 GL1500 SE 50th Annv.
Cycleman nand Gumbred.
Thanks for taking the time on this explanation.bi will check all of these.
Cycle ma'am, when you say short out you mean between the 2 terminals on the selonoid right?
Yes use a screwdriver or something with an insulated handle and short the 2 posts.
1983 GL1100, 2013 Suzuki Vstrom DL650
Previous bikes - 1971 BMW R75, 2008 HD Softail, 2000 BMW R1100R, 1980 XJ650, XT500, GS550, 77 GL1000 x2 and a few others
cycleman is offline
85 ltd died on road saltmar14 Goldwing Technical Forum 27 03-20-2013 05:29 PM
1998 GL1500 SE with 1998 Kwik Kamp trailer Wingmaster Shamus For Sale/Wanted Forum 65 10-04-2012 06:54 PM
My 1998 1500 started and died in about 1 second. poosu Goldwing Technical Forum 13 03-11-2012 09:36 PM
GL1500 Just Died Steve G Goldwing Technical Forum 4 05-16-2011 08:32 AM
died on side of the road tybme Goldwing Technical Forum 17 11-20-2008 01:08 PM
