85 LTD swapping EFI with Carbs - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 10-07-2015, 02:21 PM Thread Starter
Winger in San Diego's Avatar
Model: 1976 GL 1000 LTD; 1985 LTD (sold)
Is this possible. Having major performance issues with the fuel injection. Was suggested that I replace with Carbs. Is this possible and if so what carbs do you suggest and what all is involved. Sounds like a major can of worms to me. Thanks
"I don`t want to die; just want to ride my motor cyyyyyyyyyyycle"
Last edited by Winger in San Diego; 10-07-2015 at 02:42 PM. Reason: I found a similar thread with answers
Winger in San Diego is offline
post #2 of 7 (permalink) Old 10-07-2015, 02:47 PM
the simplest way to carbs would be to follow the Single Carb thread.
are you convinced there is no way to cure the FI blues?
post #3 of 7 (permalink) Old 10-07-2015, 02:52 PM
With 4 carbs or fabricating an induction system and a single carb is quite an undertaking if you do not have a lot of ability. I would try to solve the FI Blues.
redwing52 is online now
post #4 of 7 (permalink) Old 10-07-2015, 03:30 PM Thread Starter
That is exactly what I intend to do. Thanks Redwing!
post #5 of 7 (permalink) Old 10-07-2015, 04:35 PM
Your biggest problem would be the ignition system. It is part of the EFI system and the carbed models have a different system. Something could be figured out I'm sure.
post #6 of 7 (permalink) Old 10-07-2015, 11:19 PM
Right winger's Avatar
Year: 1985 1984
Make: Honda's 3
Model: GW Aspy & LTD, LTD 2
What seems to be the problem you are having ? What ever it is it can be solved . Probably not as bad as you think !
1984 Aspencade Premium Beige Metalic..... Right Wing
1985 LTD Sunflash Gold 85,530 Grace Brown...... Left Wing
A Bird can\'t fly on one wing
That\'s why I have three wings
And another 85 LTD, LTD 2 Sunflash Gold Grace Brown.... Tail Wing
With three wings I believe I can fly
AL
Right winger is offline
post #7 of 7 (permalink) Old 10-09-2015, 09:16 PM
So what are the issues? How is it running bad?
bruce p is offline
EFI to Carbs dennisj Goldwing Technical Forum 10 12-14-2014 03:59 PM
Swapping 1200 motors nothingbut2 Goldwing Technical Forum 1 04-30-2013 03:40 AM
Getting better at swapping tires..... Cousin Jack General Motorcycle Discussion Forum 10 08-06-2011 08:20 PM
PART SWAPPING MNPOPS Goldwing Technical Forum 3 08-22-2008 08:15 AM
Carbs and EFI stuff PatinIdaho Goldwing Technical Forum 3 05-14-2005 10:00 AM
