1500 howling noise gas tank/cap ? - Steve Saunders Goldwing Forums
  • 1 Post By DaveO430
post #1 of 7 (permalink) Old 10-12-2015, 10:42 AM Thread Starter
Snowing's Avatar
Year: 2001
Make: goldwing
Model: 1800
Hi all,
Last night after parking in the garage we heard a howling noise from what appeared from the engine area. I thought it was maybe coolant moving around at first. About 30 minutes later when I went back in garage it was still making the same noise, and there was an awful odor that I can't describe. After some searching it sounded like it was louder around the fuel cap area. As soon as I moved the fuel cap the noise began to change and after the cap was off the noise was totally gone.
We had just driven about 90 miles from the last fill and there was about a half tank of fuel left. Some sort of vapor lock?
Thoughts please.
Thanks,
Larry
Snowing is offline
post #2 of 7 (permalink) Old 10-12-2015, 10:46 AM
pretty much normal if you just came in off of a hot trip...
not to worry. it is just the fuel tank equalizing to atmospheric pressure.
the gas cap has a vent for that purpose.
post #3 of 7 (permalink) Old 10-12-2015, 10:46 AM
Year: 94
Model: 1500 SE
The rising heat from engine after shutdown expands the fuel causing some vent action
Try cleaning the cap by soaking in seafoam overnight, and verify the vent hole in rubber seal in lined up correctly
See the other recent threads on same subject for details on options for fix
Aloha Tom is offline
post #4 of 7 (permalink) Old 10-12-2015, 10:51 AM
us385south's Avatar
Year: 1996
Model: 1500
Originally Posted by Snowing View Post
Hi all,
Thoughts please.
Thanks,
Larry
After a ride, my 1500 makes what can only describe as farting sounds. I have been poo-paahed on the forum here before for this amoung other odd things my 1500 does.
My evaluation is that there appears to be a reed valve in the gas cap somewhere that chatters somewhat as the pressures equalize.
When it happens I just "burp" the gas cap, it blows a final queef at me and that's that!
us385south is offline
post #5 of 7 (permalink) Old 10-12-2015, 10:55 AM
Year: 94
Model: 1500 SE
a sickly sweet unusual smell is a coolant leak. A popular failure is the transfer hose from rad to res-
its in sections and a 90 fitting
The last piece has a built-on grommet to seal its penetration into the top of res bottle
That hose likes to break just above the grommet- a small break- enough to smell coolant on occasion and enough to allow coolant to go to the res bottle- but it CANT RETURN to refill the rad!
Ck rad level by removing cap- not trusting the res bottle dipstick in this case = it may be full or OVER-
that would be a clue~
good news is 8 dollars to Mother Honda gets a new hose with grommet.
Note Use HONDA car (good deal) or bike coolant (pricey!!!) or one that specifically says
CONTAINS NO SILICATES to top off rad,,
unless its been 2 years = then its time to do a cooling system drain/flush/refill
You have already removed the plastic pieces in the way on top, only 10 bucks of coolant and 20 minutes
to do the work.
The engine appreciates it!
post #6 of 7 (permalink) Old 10-12-2015, 11:00 AM
Year: 94
Model: 1500 SE
us385 see other thread on gas cap vent and rubber seals vent opening hole is properly oriented
Some drill out the hole for better venting and end the noise issue
post #7 of 7 (permalink) Old 10-12-2015, 02:03 PM
Once again there is nothing wrong with it, you can fix it until there is if you want.
Ken Bergen likes this.
1500 gas cap. gumbyred Goldwing Technical Forum 11 02-08-2015 12:27 PM
VENT HOSE ON 98 WING'S GAS TANK CAP- ROG ALL 49 STATES Goldwing Technical Forum 11 04-03-2011 09:39 AM
Unknown thing in GL 1500 gas tank skip20 Goldwing Technical Forum 27 01-29-2010 06:19 AM
Fuel Tank Pressure? Vented Gas Cap? gl1100ryder Goldwing Technical Forum 16 06-15-2008 12:32 PM
96 1500 Aspencade Starter,gas tank cover/false tank,battery needed adrian108 For Sale/Wanted Forum 16 07-07-2007 10:11 PM
