New TPMS sensor not transmitting - Page 2 - Steve Saunders Goldwing Forums
post #11 of 13 (permalink) Old 10-15-2015, 09:36 PM Thread Starter
Mr. kuee, Thanks!! You,sir,are a gentleman and a scholar.
TFTWO is offline
post #12 of 13 (permalink) Old 10-16-2015, 05:19 AM
Peppi-Le-Pew's Avatar
Year: 2012
Model: 2012 Blue GL1800 Level 3
I just went through this very same scenario. Tried three times by the book and gave up. Ran wires into the trunk under the carpet for future shorting purposes. Taking that seat off is a PITA. Purchased the VT tool and had the same results. I ended up going to a local dealer only to have them have problems getting the sensors to register. Dealer called Honda and got a procedure that finally worked. It took 4 total trips to get this done. If your bike is under warranty then Honda covers the repair 100%. Did you purchase the extended warranty? The sensor just can't be broken from tire replacement like mine was.
Peppi-Le-Pew is offline
post #13 of 13 (permalink) Old 10-16-2015, 06:03 AM
I went through that a lot with the sensors on Honda cars. Some worked right away, others took a few tries to get them to register. Lots of them got broken from tire changes.
TPMS Sensor/GL 18 TFTWO Goldwing Technical Forum 0 10-01-2015 06:32 PM
GL1800 OEM TPMS (Tire Pressure Monitoring System) sensor dantespard4 Goldwing Technical Forum 1 05-07-2013 03:08 AM
Flat tire on '09 with TPMS-Broken sensor in rear tire barb and dale Goldwing Technical Forum 13 07-15-2009 11:09 PM
CB Not Transmitting heyhay Goldwing Technical Forum 3 06-30-2008 07:32 PM
