1500 stalling - Page 2 - Steve Saunders Goldwing Forums
post #11 of 17 (permalink) Old 10-22-2015, 01:03 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
I got some bad gas a few years ago. Bike never did die, but had to pull to the shoulder for a bit. I would take what you can get out of it for now, and fill it back up with gasaholl free gas if you can get it. When I got bad gas, I had to take the fuel filter off about 3 times just to drain the water out of it. I would pull the fuel filter on yours and drain old gas out, replace filter, and try again. Never buy gas at that station again.
Another ting that helped my `98 S.E. was to take the gas cap off, and soak it overnight in Seafoam. Blow out with compressed air the next day. I would recommend anyone with a 1500 to do this if it has never been done before.
gumbyred
gumbyred is offline
post #12 of 17 (permalink) Old 10-22-2015, 04:38 PM
haroldaugustine's Avatar
Model: 1995 Gl1500se
What happens to the GL1500 fuel cap to cause problems? Is it all 1500's or just certain years? I have a new to me 1995 GL1500se with 154,000 miles.
“Those who surrender freedom for security will not have, nor do they deserve, either one.”
1995 Honda Goldwing GL1500se
haroldaugustine is offline
post #13 of 17 (permalink) Old 10-22-2015, 05:01 PM
Any fuel cap can clog up and no longer vent.
post #14 of 17 (permalink) Old 10-22-2015, 10:30 PM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
Vacuum leaks will cause a symptom similar to a fuel problem. Look at the intake manifolds where they attach to the heads. There are vacuum tubes that attach there and could be broken or cracked.
1500's are also known for a vacuum leak that is under the carbs at the top of the intake manifold. Not easy to get to but a well known problem.
Ray
88 GL1500
rayworx is offline
post #15 of 17 (permalink) Old 10-27-2015, 02:04 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Easiest thing to check is that the 4 Hose Clamps are snug, that connect the rubber isolators between the carbs and the intake manifold... If they are loose, then the engine will lean out (from air getting sucked in there) and idle rough. If you find it leaking, then you can often seal it by removing the carbs, then re-installing with a light coating of grease on the joint.
Next is to verify that the Vacuum Line (to the Ignition Advance) beneath the carb is intact... This is the infamous L-shaped hose that emerges from the rear side of the left intake manifold... You'll have to lift the carb to access it. Many article refer to it.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #16 of 17 (permalink) Old 11-07-2015, 06:27 AM
Peppi-Le-Pew's Avatar
Year: 2012
Model: 2012 Blue GL1800 Level 3
Originally Posted by Lgl61953a1 View Post
1997 1500SE, started having a small miss at lower rpm, straightened out around 2500-3000 rpm.
Did a couple miles of didnt-know-it-was-that-late speed, now completely stalls out at anything under 3000rpm. It will hold lower revs some in neutral, but not in gear. Seems to be OK above 3000rpm, not fun in stop and go town driving.
Any ideas? Coils?
Thanks,
Lowell
Solved yet? It would be nice to have a post indicating the solution. This is a forum of help. Others will benefit from your findings. Don't be like so many other newbies that just go away after taking from the forum.
Peppi-Le-Pew is offline
post #17 of 17 (permalink) Old 11-07-2015, 02:54 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Start with the simple stuff.
When did you last change the fuel filter?
The carb slide cleaning worked for me too.
I do it now as a maintenance item.
A vacuum leak check should be on your list too.
The problematic one under the rubber mat is a carb off item, but another problem line is off the left side manifold.
busdriver is offline
1500 Stalling The Fonz Goldwing Technical Forum 23 01-11-2014 07:54 AM
1500 stalling MICHAELR Fun Forum 4 09-27-2013 09:49 PM
GL 1500: Motor stalling on hot days Jocke Goldwing Technical Forum 37 06-30-2012 06:59 AM
Stalling smithphantom Goldwing Technical Forum 3 03-29-2007 12:33 PM
Stalling b.pete Goldwing Technical Forum 24 11-03-2005 06:42 PM
