1985 gl1200 Stator replacement - Page 2 - Steve Saunders Goldwing Forums
post #11 of 15 (permalink) Old 10-29-2015, 12:32 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
When I removed the engine on a 1200 I set the motor on wooden blocks. Unbolted the engine and pulled the frame to the side.
Of course nearly everything else was already off the frame so it was light.
JeffMayfield is offline
post #12 of 15 (permalink) Old 10-29-2015, 05:51 PM
CrystalPistol's Avatar
How they do it is slide the motor to the left a few inches, then twist it enough to get at the bolts on the stator cover. All of the motor bolts have to come out and the carbs are disconnected, lifted and held up with bungies.
The electrical connections don't need to be unplugged, nor do the fuel lines.
Really it's not a lot less work than just pulling the engine out but doesn't require a second person.
Yeah ..... I can see that. Maybe "build" a platform up under it?
I did a R&R of the stator back in the October 1997 alone in evenings one week after work. Used a piece of 1/2" plywood cut to same size as bottom of motor, added ribs on top side to interlock with cooling fins, etc of engine to "lock" it in place in use when weight applied so engine would not slide off plywood .... then in approximate center on bottom of plywood, I attached a second piece of 1/2" plywood with a round hole cut in center that was a little bigger than the lifting foot or plate on my 1.5 ton small floor jack. Used wood glue and a few brads. With it, when time came, I was able to guide, jack, the jack with one hand and simply balance the engine with the other. "Center" turned out to pretty near "center of balance".
Rolled away and eased down onto two wood blocks.
Reverse to put back.
...(Candy Spectra Red )
CrystalPistol is online now
post #13 of 15 (permalink) Old 10-29-2015, 08:13 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
Related thoughts,
Just realized that I could use some of these methods to separate my 1000 engine from it's frame so that I can powder coat the frame. I have the tools, material and access to a humongous oven.
I like the jack ideas. Thinking now, do I want to remove the engine away from the frame, or the frame away from the engine?
What's best, easier, less destructive on paint and parts?
Balance and move the engine or drag away the frame?
Oh yeah, they got to go back together too.
Scott
Send lawyers, guns and money
1975 GL 1000, Fermenting
mrtwowheel is offline
post #14 of 15 (permalink) Old 10-30-2015, 06:58 AM
Originally Posted by mrtwowheel View Post
Related thoughts,
Scott
If you are stripping the frame down anyway block the engine up and lift the frame off.
post #15 of 15 (permalink) Old 11-02-2015, 08:40 PM
Right winger's Avatar
Year: 1985 1984
Make: Honda's 3
Model: GW Aspy & LTD, LTD 2
Related thoughts,
Scott
I took mine out with my bike jack . It's a one man job . Came out real easy too
1984 Aspencade Premium Beige Metalic..... Right Wing
1985 LTD Sunflash Gold 85,530 Grace Brown...... Left Wing
A Bird can\'t fly on one wing
That\'s why I have three wings
And another 85 LTD, LTD 2 Sunflash Gold Grace Brown.... Tail Wing
With three wings I believe I can fly
AL
Right winger is offline
1985 GL1200 Aspencade Stator Wires Scot Thompson Goldwing Technical Forum 9 06-28-2014 09:45 PM
GL1200 Stator replacement Pauly G Goldwing Technical Forum 15 07-29-2013 10:28 PM
For Sale - Stator Goldwing GL1200 1985 LTD / 1986 SEI Metal99 For Sale/Wanted Forum 1 10-02-2011 02:04 PM
Stator replacement GL1200 rustymich Goldwing Technical Forum 23 02-15-2010 07:36 PM
GL1200 Stator replacement joe1970 Goldwing Technical Forum 6 07-06-2007 11:29 AM
