Make your own steering stem bearing tools - Page 3 - Steve Saunders Goldwing Forums
post #21 of 42 (permalink) Old 11-08-2015, 07:59 PM
Originally Posted by Quick Cal View Post
But I may not be able to weld the hardened socket anyway.
If the weld fails "unlikely" you've just lost a broken socket, a dollars worth of pipe and some time.
What's that old saying (Nothing ventured nothing gained)?
Ken Bergen is online now
post #22 of 42 (permalink) Old 11-08-2015, 08:24 PM Thread Starter
Quick Cal's Avatar
Model: 84 1200 Interstate
I just talked to my welder. He says you can't weld the black pipe. It will crack. And like John said. If I get the socket hot enough to weld it will melt everything else.
My welder said I don't want to use pipe. He says use tubing. It's the right kind of steel. He said he might have some that will work.
Then he said he could use a cnc machine to make me a square hole in a piece of round stock and weld that in the tubing. Then I could use my torque wrench.
That's all well and fine. But there goes my glory of building my own tool. I think I'll still make one that the every day Joe can make. Just to do it,,,lol.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
84 GL1200 Interstate
Quick Cal is offline
post #23 of 42 (permalink) Old 11-08-2015, 08:53 PM
That's the spirit.
Just do it and the experts be damned.
post #24 of 42 (permalink) Old 11-08-2015, 08:59 PM
Maybe I missed something in the thread, but why not just grind down the appropriately sized 1/2" drive socket so you have the 4 "tabs" to grab the adjustment nut? That's the only special tool required. The locknut doesn't need a tool, it's only hand tight and the stem nut, if I recall, is just a standard 30mm socket.
spiralout is offline
post #25 of 42 (permalink) Old 11-08-2015, 09:46 PM Thread Starter
Quick Cal's Avatar
Well I don't have the right size socket. But I did just look on ebay. I can get a cheapie if I knew what size.
I haven't tore my bike apart yet. But I'm using a spare steering stem from a 1200 that I have for mock up. The stem nut on it is a 4 prong. So the tool would be just like for the lower nut except smaller.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #26 of 42 (permalink) Old 11-08-2015, 10:01 PM
You're right, idk what I was thinking. It's just like the nut on the 1100. Guess I've just gotten used to the 1500.
post #27 of 42 (permalink) Old 11-08-2015, 10:23 PM
If you have the nuts off your spare stem, just take them with you to a pawn shop and compare the O.D. and wall thickness of the ones they have in the two dollar bin
post #28 of 42 (permalink) Old 11-08-2015, 10:51 PM
Here's a start.
post #29 of 42 (permalink) Old 11-09-2015, 09:10 AM
fatwing chris's Avatar
Here's my homemade version.The slots are for re-torquing later if need be,so you don't have to disconnect your wiring.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #30 of 42 (permalink) Old 11-09-2015, 09:20 AM Thread Starter
Quick Cal's Avatar
Can you elaborate on how you made yours.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
steering stem tools Big John .25 Goldwing Technical Forum 6 01-30-2012 10:10 PM
GL1800 Steering stem bearing replacement Hidepounder Goldwing Technical Forum 5 10-20-2011 06:52 AM
gl1800 Steering Stem Bearing abady Goldwing Technical Forum 1 04-14-2011 08:03 PM
steering stem tools zook Goldwing Technical Forum 4 04-06-2011 11:57 AM
Steering stem bearing install tool Craig Gulley Goldwing Technical Forum 11 12-13-2008 12:55 AM
