Make your own steering stem bearing tools - Page 4 - Steve Saunders Goldwing Forums
post #31 of 42 (permalink) Old 11-09-2015, 05:20 PM
jobe05's Avatar
Model: 1500 & 1800
I made one from galvanized and the teeth were not strong enough.
I did put the socket inside the pipe, then drilled a hole through the socket and pipe and put a nut and bolt on it, worked fine, till the teeth broke.
You can try to harden the black pipe once completed by heating it up (red hot) and quickly dipping it in oil (Used motor oil is fine).
Honorary Rhino.......
jobe05 is offline
post #32 of 42 (permalink) Old 11-09-2015, 05:36 PM Thread Starter
Quick Cal's Avatar
Model: 84 1200 Interstate
I swear I was just thinking about the teeth breaking. Must be esp,,,lol.
Maybe I should just make it out of a 36mm socket. Nut man. They aint cheap.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
84 GL1200 Interstate
Quick Cal is offline
post #33 of 42 (permalink) Old 11-09-2015, 06:17 PM Thread Starter
Quick Cal's Avatar
I wonder if the galv would break easier than the black.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #34 of 42 (permalink) Old 11-09-2015, 06:39 PM
I'm telling ya, hit a pawn shop for a used one since you're going to grind on it anyway.
spiralout is offline
post #35 of 42 (permalink) Old 11-09-2015, 07:19 PM
jobe05's Avatar
Model: 1500 & 1800
Don't forget, we do have a tool loaner program, and we have 2 sockets available, or for $35 you can get one off EBay........
I understand it's not as much fun as making your own...... been there, done that....
jobe05 is offline
post #36 of 42 (permalink) Old 11-09-2015, 08:42 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Might have a snag.
I just talked to a guy in welding school. He says you may not be able to weld the hardened socket to the washer. Any ideas on that??
I'll have to ask my regular welding expert.
If that won't work I'll have to start from scratch. Dam!!
Yea , you might want to speak with your " regular welding expert" and leave the student in school a while longer
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
post #37 of 42 (permalink) Old 11-10-2015, 07:29 PM
fatwing chris's Avatar
Can you elaborate on how you made yours.
Just used black pipe and welded keystock onto it.Welded a cap on the top and then welded an old 3/8" 3 " extention into it.There's no real torque where this is used,so it really doesn't need to be all that strong.The other short socket was just an old socket that I had around.Cut the slots in with a die grinder with a cut-off wheel in it.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #38 of 42 (permalink) Old 11-10-2015, 07:34 PM
How'd you break the teeth off when the spec is only 14 to 20 ft. lbs. for the preload and then basically finger tight on the top castle nut?The nut on top of the bridge is the only one that has any real torque on it.
Fatwing Chris
Darkside #1602
post #39 of 42 (permalink) Old 11-10-2015, 09:49 PM Thread Starter
Quick Cal's Avatar
Anyone know if the upper steering stem nut that goes above the bridge is the same thread for the 1200 and the 1500.
The 1200 uses a washer and a 4 slotted nut that requires the special tool. And that gets torqued to 70 ft lbs. So those teeth might break with a home made tool.
The 1500 uses a flanged nut that you can put a socket on.
If I could use a 1500 nut on my 1200 I would only have to make one tool.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
post #40 of 42 (permalink) Old 11-10-2015, 10:01 PM Thread Starter
Quick Cal's Avatar
BTW. I googled about welding black pipe. Turns out it is not "Black Iron" pipe at all. It was just called that at some point in time and the name stuck. It is not iron. You can weld the crap out of it. It's just mild steel.
I may not make the upper tool out of it since it is mild steel and the teeth make break as mentioned above. Besides. I do have a junk 1" impact socket that I think will work for the upper tool. Unless I find out that a 1500 stem nut will work, I'll just use the socket.
Can't remember what kind of tool I made out of this socket before. Must have worked,,,,lol.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
steering stem tools Big John .25 Goldwing Technical Forum 6 01-30-2012 10:10 PM
GL1800 Steering stem bearing replacement Hidepounder Goldwing Technical Forum 5 10-20-2011 06:52 AM
gl1800 Steering Stem Bearing abady Goldwing Technical Forum 1 04-14-2011 08:03 PM
steering stem tools zook Goldwing Technical Forum 4 04-06-2011 11:57 AM
Steering stem bearing install tool Craig Gulley Goldwing Technical Forum 11 12-13-2008 12:55 AM
