Make your own steering stem bearing tools - Page 5 - Steve Saunders Goldwing Forums
post #41 of 42 (permalink) Old 11-11-2015, 07:33 AM
m2102's Avatar
Year: 2001
Make: honda
Model: gl 1800, red of course
Send a message via AIM to m2102
If it helps, the it's on the 1500 are same size as the 1800. I believe threads are same also.
2001 GL1800
m2102 is offline
post #42 of 42 (permalink) Old 11-11-2015, 12:22 PM
fatwing chris's Avatar
Originally Posted by Quick Cal View Post
Anyone know if the upper steering stem nut that goes above the bridge is the same thread for the 1200 and the 1500.
The 1200 uses a washer and a 4 slotted nut that requires the special tool. And that gets torqued to 70 ft lbs. So those teeth might break with a home made tool.
The 1500 uses a flanged nut that you can put a socket on.
If I could use a 1500 nut on my 1200 I would only have to make one tool.
Mine was built for my 1500 and it had a regular nut on top,but even if it had a castle nut the way it was made 70 ft. lbs, wouldn't shear the teeth off.Haven't had the need to try it on the 1800 yet.
Actually come to think of it I didn't use key stock for the teeth,it was just regular 1/4 x 1/4" steel stock.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
steering stem tools Big John .25 Goldwing Technical Forum 6 01-30-2012 10:10 PM
GL1800 Steering stem bearing replacement Hidepounder Goldwing Technical Forum 5 10-20-2011 06:52 AM
gl1800 Steering Stem Bearing abady Goldwing Technical Forum 1 04-14-2011 08:03 PM
steering stem tools zook Goldwing Technical Forum 4 04-06-2011 11:57 AM
Steering stem bearing install tool Craig Gulley Goldwing Technical Forum 11 12-13-2008 12:55 AM
