'89 GL1500 Acceleration hesitation off idle - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 11-08-2015, 01:22 PM Thread Starter
CallCar54's Avatar
Year: 2003
Make: Honda Goldwing 1800
Model: Trike with Motor Trike kit
My 89 Goldwing has had the carbs cleaned and rebuilt, fuel pump replaced and fuel filter. It will idle and rev great in neutral but as soon you put it in gear to drive it hesitates and bogs down. There is no power at all when trying to pass in 4th gear or OD. I have read many articles but cant seem to find anything that has fixed the problem. Any help would be appreciated.
CallCar54 is offline
post #2 of 6 (permalink) Old 11-08-2015, 01:28 PM
That unfortunately is a fairly common condition for 88 especially and the 89 to some extent.
and, it can also happen to any of the 1500s if there is the tiniest of pinhole leaks in the vacuum system anywhere.
I am moving your post to a separate thread where "You" will get personal attention. Tacking onto the bottom of an old thread will get you ignored if folks look and say, I have already helped "that guy". "That guy" is the one who starts a thread, and since you did not, you might get ignored.
post #3 of 6 (permalink) Old 11-08-2015, 01:31 PM
if you will look in the top of the General Forum, we have a Forum Topic Index:
follow that link and install your own bookmarks, that is where these came from:
Hesitation problem on 88 89 bikes
Hesitation Links via Search:
https://www.goldwingfacts.com/forums/...223j8444753j38
88 Off Idle Hesitation, Recall, Carb. 'Upgrade' Parts, Trigger Wheel.. - Goldwing Technical Forum - Forums - Steve Saunders Goldwing Forums
88/89 Hesitation - by Agnogel * great article
post #4 of 6 (permalink) Old 11-08-2015, 07:21 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
I would start by running a vacuum test on the vacuum fuel shut off valve. Right ahead of gas cap. Should hold a good vacuum.
gumbyred
gumbyred is offline
post #5 of 6 (permalink) Old 11-09-2015, 04:08 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
gumbyred
It's simpler to Bypass the shut off valve... If the problem disappears, then it's a fuel starvation issue.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #6 of 6 (permalink) Old 12-29-2015, 09:57 AM
mightymousesr's Avatar
Year: 2010
Model: GL1800/Lehman Trike
Had the same problem with my 1500! Did the filter thing, Vacuum thing, Carb rebuild thing. Long story short... When I changed the fuel filter it had collapsed (actually it was an emco it had dissolved) I didn't give it a thought until the "Hesitation" I tried everything to get rid of the hesitation. Checked my accelerator pump squirters they weren't giving a squirt of fuel! It turned out to be the accelerator pump transfer tube! It has a B.B. in it so fuel stays up by the squirters some of the junk from the old filter got up in there and wouldn't let the check BB move. Got a new one from Honda, problem solved. you can replace it externally without removing the carbs. or the linkage.
Those that think "Old means Slow" have NEVER ridden a V65 Magna.
mightymousesr is offline
91 GL1500 slight hesitation off idle Happytrails Goldwing Technical Forum 1 05-14-2015 10:15 PM
GL1500 Acceleration hesitation off idle dlkorock Goldwing Technical Forum 8 06-20-2013 10:44 PM
88GW GL1500 off Idle Hesitation oldtimer100 Goldwing Technical Forum 35 07-15-2012 02:32 AM
GL1500 rear brakes and missing at low idle acceleration nacnud67 Goldwing Technical Forum 17 11-07-2011 04:38 PM
Failed Emissions and Acceleration Hesitation Curb the Wingrider Goldwing Technical Forum 1 05-26-2006 02:29 PM
