Goldwing 1800 stiff ride. - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 11-12-2015, 10:56 PM Thread Starter
icu2's Avatar
Since my front seals on my 2010 GoldWing 1800 were changed, my Trike rides stiff, like a log truck! Has anyone else had this problem? And what did you do to correct it. The local Honda dealership can't figure out the problem. The anti-dive is disabled. Honda sent a new front fork, no cost, but that did not cure the problem. Any help sure would be appreciated.
icu2 is offline
post #2 of 8 (permalink) Old 11-12-2015, 11:02 PM
Magic Moderator
trike lady's Avatar
Did they use the right weight fork oil? Overfill the forks?
Did the trike ride rough prior to the seal change?
Retired trike builder.
trike lady is offline
post #3 of 8 (permalink) Old 11-12-2015, 11:07 PM Thread Starter
icu2's Avatar
Trike rode fine prior to seal being changes. I asked the tech if he possibly overfilled the forks and he said no, even after he changed the left fork he was very careful with the oil level. I'm wondering if he should have used 20 weight instead of recommended 10 weight. Hope I didn't get that backward!
icu2 is offline
post #4 of 8 (permalink) Old 11-12-2015, 11:32 PM
5w is better, 20w is like a brick, the forks won't move.
post #5 of 8 (permalink) Old 11-13-2015, 05:59 AM
Are you sure the ADV is still disabled?
post #6 of 8 (permalink) Old 11-13-2015, 07:47 AM
Red Ron's Avatar
Year: 2013
If they notice the anti-dive disabled they will enable it. Dave0430 is right. You might want to check and see.
May the good Lord Jesus bless us all!!
Red Ron is offline
post #7 of 8 (permalink) Old 11-13-2015, 08:29 AM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
Make sure the dampener in the right fork leg is ok
or
make sure the ADV is still deactivated. If not then obviously it's stuck
or
disassembly of the forks is needed to make sure all is done correctly
Having said all that, now your forks are no longer letting pressure escape, though leaking seals, suspension will feel stiffer,IMO
tfdeputydawg is offline
post #8 of 8 (permalink) Old 11-13-2015, 05:37 PM
fatwing chris's Avatar
Also possible that they didn't follow procedure for mounting the front wheel.Forks could be binding up because of this.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
1800 stiff rear shock and lousy forks! pippomaranga Goldwing Technical Forum 31 07-10-2014 05:31 PM
I rode 1200 1500 1800 and 2012 1800 in one ride motomike1sf General Motorcycle Discussion Forum 33 11-06-2012 07:19 AM
GL1500 stiff ride on front end SailorKane Goldwing Technical Forum 1 09-03-2009 09:04 PM
Progressive Spring to Stiff? 01 GoldWing Buddy1 Goldwing Technical Forum 6 05-30-2009 11:51 PM
1980 Goldwing, Stiff Throttle plumpleg Goldwing Technical Forum 6 09-13-2008 10:27 PM
