Lower Driving/Cornering Lights Out - Page 2 - Steve Saunders Goldwing Forums
post #11 of 21 (permalink) Old 11-16-2015, 10:56 PM
Here in Wisconsin you need them on all the time. In the spring the ground is cold and the asphalt holds heat from the daytime sun. If you go down old blacktop roads the raccoons sleep on the nice warm asphalt. I didn't notice one and kicked it. It scared me more than hurt me. Wonder what the coon thought. Can't get a quiet nights sleep anymore????
redwing52 is offline
post #12 of 21 (permalink) Old 11-17-2015, 03:00 PM
rgmr250's Avatar
Model: 97 gl1500 SE
My understanding is that the 98-00 GL1500's had the 'cornering' (I think they are actually 'driving' lights and the design is different) lights on all the time. My 97 only has them come on when the turn signal is on.
According to Cyclemax in the text about the lower cowl driving lights they sell: "They stay on all of the time just like the 1998-2000 driving lights and plug in to the factory wiring harness" http://cyclemax.com/inc/sdetail/gl15..._lights/83/321
Current rides:
2010 Husqvarna TE250
2015 Kawasaki Ninja 650
2008 GL1800 with bagger kit
1997 GL1500SE
rgmr250 is offline
post #13 of 21 (permalink) Old 11-17-2015, 03:46 PM
You are correct. Even so you have to watch for the coons out there.
post #14 of 21 (permalink) Old 11-17-2015, 05:35 PM
fatwing chris's Avatar
The cornering lights do next to nothing as far as lighting up the road no matter what size bulbs you use.They are on too much of an angle towards the ditch.The only real advantage to lighting them all the time is that the bike looks much bigger coming towards you.If you want real driving lights you will have to change them out so the bulbs actually point in the right direction.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #15 of 21 (permalink) Old 11-17-2015, 06:36 PM
rgmr250's Avatar
Model: 97 gl1500 SE
My thoughts too. I've been eyeing the 50W LED lower cowl driving lights at Cyclemax. 100W of combined LED lighting would be handy. It would help with visibility (both me being able to see and oncoming cars seeing me.)
Current rides:
1997 GL1500SE
rgmr250 is offline
post #16 of 21 (permalink) Old 11-17-2015, 08:28 PM
Year: 94
Model: 1500 SE
the lower cowl lights will make you bright to oncoming traffic, but the pattern and angle will remain to the front sides
Not much help in lighting the roadway
For that job you want some `cans`/aux lights, with LED and a narrow 10-15 degree spread.
Mount to crash bars or hide into the cowling. some mount to front forks- giving you real light on the road as you turn into the dark corner
Aloha Tom is offline
post #17 of 21 (permalink) Old 11-18-2015, 02:30 PM
rgmr250's Avatar
Model: 97 gl1500 SE
I'm hoping/expecting that these ones from Cyclemax have the reflector setup differently so that they actually project more down the road and not just to the side: http://cyclemax.com/inc/sdetail/gl15...ghts/83/195210
Anybody install these? Any comments on the light output/direction?
I do like the idea of the 10-15 degree LED spots mounted to the forks, so the light goes where the forks are pointed. You still have the angle problem when you lean the bike over (not like the adaptive headlight system on the BMW K1600GTL), though.
Current rides:
1997 GL1500SE
rgmr250 is offline
post #18 of 21 (permalink) Old 11-18-2015, 05:08 PM
They'll work.Says they're driving lights as opposed to cornering lights.You could also use the 98 to 2000 OEM lights also as they are driving lights.
Fatwing Chris
Darkside #1602
post #19 of 21 (permalink) Old 11-18-2015, 08:32 PM
Year: 94
Model: 1500 SE
anyone else grow up with a bike where the headlight turned with the forks?
Getting used to the Wings car-like straight ahead setup... felt very odd on a motorcycle~
Fork mounted LEDs are on my wish list. Darkness comes before 5pm now- and the roads I like to enjoy a casual cruise on are totally unlit for 50+ miles, but still have all the corners!
Heated gear makes evening rides possible, comfortable even,,,if only I could see into the corner!
sidenote: ck craigslist for used heated gear, often a retiring rider of H-D or Wing lets a set go for cheap..
50 bucks each would be a steal
post #20 of 21 (permalink) Old 11-18-2015, 09:29 PM
It's only the faired GLs that the headlight is like that. There were three models before your 1500 that had the headlight on the forks.
Or you could get a bike that the headlight actually turns with the corners. If I ever have an extra 30 large to spend on a bike, it'll be the K1600GTL
https://youtu.be/7vNESfn3nYw?t=34
spiralout is offline
New LEDS for cornering/driving lights VDIGUY Goldwing Technical Forum 13 02-26-2015 11:44 AM
GL1500, cornering lights or driving lights?? pippomaranga Goldwing Technical Forum 9 01-17-2012 02:20 PM
Difference between fog/driving lights and cornering lights? kemoloney Goldwing Technical Forum 15 11-12-2011 09:31 PM
Driving/Cornering lights itsofficial Goldwing Technical Forum 1 06-18-2008 03:39 PM
Driving vs Cornering lights amosheath General Motorcycle Discussion Forum 18 03-10-2008 10:47 AM
