Firecreek gauges on a 1500SE - Steve Saunders Goldwing Forums
 9Likes
post #1 of 29 (permalink) Old 11-22-2015, 08:01 AM Thread Starter
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
I've bought a blank Firecreek key cover to install two gauges. I definitely want one of the gauges to be a voltmeter but can't decide whether the other gauge would be better being coolant temperature or oil pressure. Before I decide, has anyone fitted these? I would be interested to know where is the best place to install the coolant sensor or oil sensor? I'm hoping there is a 'T' piece I can get to make life easy. Attached is a picture of a Firecreek gauge set up for those who might not have heard of them.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
post #2 of 29 (permalink) Old 11-22-2015, 11:36 AM
Unofficial Youtube Addict
Happytrails's Avatar
Model: 1991 Goldwing SE Anniversary Edition
I'd go with the oil pressure since you already have a temp gauge.
"riding is good therapy"
Happytrails is offline
post #3 of 29 (permalink) Old 11-22-2015, 12:03 PM
Power Guy's Avatar
Model: Aspencade 1500
I have that exact gauge set on my wing. One gauge is voltage, the other is Oil pressure. (Have not fully connectet the oil pressure gauge yet) need to find some instructions on how to install oig gauge,
Power Guy is offline
post #4 of 29 (permalink) Old 11-22-2015, 02:50 PM
Bellboy40's Avatar
Year: 2000 & 1994
This is my thoughts exactly.
Larry
-- Albert Einstein
Bellboy40 is offline
post #5 of 29 (permalink) Old 11-22-2015, 02:58 PM Thread Starter
John J's Avatar
Year: 2006
Model: GL1800A6
I would prefer having the oil gauge too. My original question is how to connect the gauges. The matching sets I've been looking at only have oil and coolant gauge options that match the voltmeter I want, therefore, if the oil is too much of a job to connect I would go with the coolant.
John J is offline
post #6 of 29 (permalink) Old 11-22-2015, 03:18 PM
Bellboy40's Avatar
Year: 2000 & 1994
The oil pressure sensor is located under the front cover. It is screwed in near the oil filter and has a wire connected to it. You might be able to find a T-fitting to go there to connect the sensor for your new gauge. The oil pressure sensor is 1/8 inch pipe thread.
Aloha Tom likes this.
Larry
-- Albert Einstein
post #7 of 29 (permalink) Old 11-22-2015, 03:33 PM Thread Starter
John J's Avatar
Year: 2006
Model: GL1800A6
Thanks Bellboy that is a big help. Now I know the thread size I can start hunting around for T fittings that might work. I think my problem might be that the gauge fittings I buy will have a metric thread which might make it harder to find aa something that can cope with both thread types. Anyway, a good start thanks again. By the way, I use the electronic manual you sent me long ago a lot. So much better than Haynes.
John J is offline
post #8 of 29 (permalink) Old 11-22-2015, 07:35 PM
Bellboy40's Avatar
Year: 2000 & 1994
Hey John J, Good to know you are using and enjoying the service manual. Actually that is where I found the thread size for the oil pressure sensor. Look on page 2-8. It is the first item under Lubrication. Hope you can find what you need to get the oil pressure gauge hooked up.
Larry
-- Albert Einstein
post #9 of 29 (permalink) Old 11-22-2015, 07:46 PM
Friend of Bill W.
LarryInSeattle's Avatar
Model: 1800A
I had outside air temp and volt meter on mine.
For
Friends, Fun, Safety & Knowledge check out the GWRRA
2002 1800 Goldwing
2005 Honda Silverwing 600cc Maxiscooter
2007 900cc Kawasaki Classic LT
The Forum removes the time and distance between like minded individuals. It is quite the communication tool. I give great thanks to the owners of the board.
“Let me never fall into the vulgar mistake of dreaming that I am persecuted whenever I am contradicted.” Ralph Waldo Emerson.
LarryInSeattle is offline
post #10 of 29 (permalink) Old 11-22-2015, 09:09 PM
moparnut38's Avatar
Model: 1996 Goldwing SE/ 1998 Goldwing SE
Power Guy.....where did you get your gauges? I have the same panel with no gauges and looking too get some so I can install it on my wing.
I want too put the outside temp gauge and volt meter in mine
moparnut38 is offline
ebay firecreek guage panel with led gauges CWN For Sale/Wanted Forum 4 10-23-2015 09:16 AM
For sale firecreek panel and gauges knklehd1 For Sale/Wanted Forum 6 04-10-2015 12:16 PM
FireCreek Panel Redeye1620 For Sale/Wanted Forum 1 07-04-2012 07:15 PM
White faced Speedo and Tach Gauges on 1500SE??? crooner General Motorcycle Discussion Forum 16 06-29-2011 01:13 PM
Firecreek HP-S rkjjeep General Motorcycle Discussion Forum 32 10-15-2005 09:18 PM
