Frame Cracks 02/03, how many ? - Page 3 - Steve Saunders Goldwing Forums
 2Likes
post #21 of 27 (permalink) Old 11-28-2015, 08:31 AM
Originally Posted by CWN View Post
Need I say more :<)
Service Bulletins for GL1500
SB1 1988 GL1500 Carburetor Vent Hose Routing
SB2 1988 GL1500 Low Speed Driveability Improvement
SB3 GL1500 CB Radio Sub Harness
SB4 1988-1989 GL1500 Saddlebag Water Leakage
SB5 1988-1989 GL1500 Improved Windshield Seal
SB6 1988-1993 GL1500 Bank Angle Sensor Replacement
SB7 1997 GL1500C Valkyrie Turn Signal Bracket Replacement
SB8 1997-1998 GL1500C/CT Valkyrie CB Radio Kit
SB9 2000 GL1500A/SE Defective 3 Way T Fitting To The Air Injuction Control
SL34 1997 GL1500C Leather Saddlebags Hardware Replacement.
Well, yes, what's your point? This thread is about 1800 frame cracks, not 1500s, or anything else.
AZgl1800 and tomsh2012 like this.
post #22 of 27 (permalink) Old 11-28-2015, 09:03 AM Thread Starter
wingit2u's Avatar
Year: 03
Make: Goldwing Champ trike 1800 and BMW 1200
Model: GL1800 Champ trike
I think there is some confusion about frame crack history.
Some say mine was done, which could mean, inspected, or gussets added
for repair or preventive ideas. Im surprised cracks show up all over
in un related area's to each other. Its a week frame.
Although its my first Honda, I'v ridden since the 60's, owned a Tool & Die shop 36 years,
and made parts for Planes, Boats, Trucks, Bikes, Caterpillar.
It seems a week frame can be trashed by the right pot hole years later.
Honda is using the trike excuse to cheat us..Its bad and confidence is gone for me.
But Have a wonderful ride fellow un intentional test pilots.
wingit2u is offline
post #23 of 27 (permalink) Old 11-28-2015, 09:09 AM
fatwing chris's Avatar
Chris, should I be shaking in my boots?
I suspect that if my '02 had a bad weld, it would have showed up quite a while ago. The PO installed the Traxxion suspension on it many years ago and I would think that if it was going to crack, that it would have by now.
It's not the welds that are breaking now.It's the tubes behind the passenger footrests that basically hold the back end of the bike together.The tubes are so thin that they claim there is no way to properly repair them.Like I said before mine is one of the patched up frames from late 04 and yes I keep a pretty close eye on it.Honda Canada doesn't appear to be as forthcoming about replacing frames still as she is in the States.Maybe I should just pawn it off on someone that is still convinced it's not an issue.Oh wait a minute I actually have a conscience so that won't work.
BTW I've also read that while this is a safety recall there is a sort of "Statute of Limitations" on it.So after a point Honda replacing them becomes more of a goodwill thing.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #24 of 27 (permalink) Old 11-28-2015, 09:47 AM
lionelgo50's Avatar
Wonder why my search didn't turn up the 03-04 recall?
Dave, I just looked at your pdf link, On page 15 I believe svc bulletin #18 revised April 2009 shows 2003 & 2004 frame weld recall
You had it covered
Dave
Ride Safe and Ride Often, Keep the Shiny Side up and Many Happy Miles and Smiles.
In God We Trust; All Others Must pay Cash!!!
Current Goldwing 2016 Gl1800 Matte Silver
Other Rides
2007 Honda 110cc
Past Rides
2 1985 Goldwing Aspencades, 2006 Harley Davidson Sportster 1200, 2006 Goldwing Navi, 2007 Honda Rebel, 1994 1500cc Goldwing Interstate, 2010 Gl1800 Trike, 1997 GL1500 SE, 2012 Harley Davidson Heritage Softail
lionelgo50 is offline
post #25 of 27 (permalink) Old 11-28-2015, 09:52 AM
Bellboy40's Avatar
Year: 2000 & 1994
Yeah Dave, your mistake was in thinking you made a mistake!
Larry
-- Albert Einstein
Bellboy40 is online now
post #26 of 27 (permalink) Old 12-05-2015, 11:13 AM Thread Starter
wingit2u's Avatar
Year: 03
Update My thanks to Moon Motors all brands Mn.
Im feeling much better after visiting Earl Moon, the best mechanic I ever knew.
My frame was re welded years ago where the welds were lite from Honda.
Being new to Wings, I asked to check it out, and check the anti dive valve, stuck.
The brake fluid was old and dirty, thats not Honda's fault. Some people are cheap.
The brake re call might include all wings. I left with new master Cyls and flushed again.
Then I found trike dealer who did 600+ kits and he saw almost no crack problems.
If your trike wasn't re welding when this was news, A local Tig welder can save the bike.
We are looking forward to traveling with the Wing Champ trike.
Happy Day
wingit2u is offline
post #27 of 27 (permalink) Old 12-06-2015, 09:05 AM
Im feeling much better after visiting the best Wing/BMW dealer I use for many years.
Happy Day
Even the best of welders can only do so much if the base product is too thin.It would just re-break beside the repair eventually.
Fatwing Chris
Darkside #1602
frame cracks RonHochhauser Trikes, Trailers and Sidecars 8 08-05-2015 11:59 PM
Cracks and noise circlepilot Goldwing Technical Forum 8 09-12-2011 11:38 PM
Just found these pics of 1800 frame cracks siataukreg Goldwing Technical Forum 15 08-12-2008 05:25 PM
Spider Cracks in the Trunk. Trainertim77 Goldwing Technical Forum 1 08-17-2007 09:12 PM
