Searching for more rear light - Steve Saunders Goldwing Forums
post #1 of 22 (permalink) Old 12-07-2015, 02:27 PM Thread Starter
Smurfhawk's Avatar
Model: 1800
Here's the deal ,would like to replace rear brake/tailights on 2002 wing with out the full explanation of electrical engineering terms and braking the bank what would be a good replacement for the oem bulbs.HID or LED .any links appreciated...
Smurfhawk is offline
post #2 of 22 (permalink) Old 12-07-2015, 03:08 PM
Maybe Leds, there is no such thing as HIDs for rear lights that I know of.
Try https://www.google.com/url?sa=t&rct=...-JXOfJWcMUxPVg
post #3 of 22 (permalink) Old 12-07-2015, 05:57 PM
rgmr250's Avatar
Model: 97 gl1500 SE
Don't be tempted by the cheap Chinese stuff on eBay. Been there, done that. Most of them were not even as bright as the stock incandescent bulbs, or had a really bad light pattern. I got lucky with some, after trial and error. Keep in mind that putting LED's in on turn signals (i know you didn't mention this) will require ballast resistors (I don't recommend) or an electronic flasher, otherwise you'll get no flashing or 'hyper' flashing.
SuperBrightLEDs.com - as Dave referenced - are a good place to start, as they actually list brightness levels and field (width) of light. Most housings have reflectors designed for regular bulbs and putting LED's in may not put the reflectors to good use - making them really bright directly behind you, but not bright at all if viewed off-angle (anything other than straight behind.)
Happytrails likes this.
Current rides:
2010 Husqvarna TE250
2015 Kawasaki Ninja 650
2008 GL1800 with bagger kit
1997 GL1500SE
rgmr250 is offline
post #4 of 22 (permalink) Old 12-07-2015, 06:44 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
I replaced my tail lights and turn signals on two of my bikes with Pilot brand LEDs from Walmart, also every light on my trailer. I'm real happy with the Pilot LEDs. I'm not sure if you will get brighter lights from LEDs, unless you add sockets and more lights.
Scott
Send lawyers, guns and money
1975 GL 1000, Fermenting
mrtwowheel is offline
post #5 of 22 (permalink) Old 12-07-2015, 07:25 PM
joe in calif's Avatar
On the 1800 only 1 of the lights in the trunk is a brake light, both are 2 filament and running lights but only 1 is a brake light. You can make a jumper wire from 1 light to the other and make both of them running and brake lights. About a 10 minute job. Here is my 08 after I made the mod. Of course I also added the trunk spoiler and brake light. Also you can change the reflector at the bottom of the rear panel to a light also.
A NEW START ON 1/20/2017
joe in calif is offline
post #6 of 22 (permalink) Old 12-07-2015, 07:53 PM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
I don't know if the "tail lights" in an 1800 are the same as a 1500, but I also replaced mine with the Pilot LED 1157 bulbs available at Walmart. The LEDs were exactly as bright as the standard bulbs, no brighter, no dimmer. Being LED, they also work a lot better than incandescent bulbs when 'flashed', like by a brake light flasher. That is due to the instantaneous ON / OFF nature of LEDs. The flashing is much more noticeable.
Walmart had them for $15 a pair. You need RED in a red light fixture.
Thomas Paine December, 1776
Bluewaterhooker0 is offline
post #7 of 22 (permalink) Old 12-07-2015, 09:22 PM
OldNewbie's Avatar
Year: 2003
Make: GL1800
Model: Wing
Tried the pilots and didn't care for them as while they are bright to look at they do not reflect out of the lens as well and were not red for red lens. The led's around the bulb do not direct much into reflector for proper reflection outward.
At wallyland the Zevo series ARE red and high output, and led's are aimed into curve of reflector.
However I prefer the Phillips Vision LED which are available in 1157 and 7443 flavors for both the 1500 and 1800 with 4 high output led aimed into reflector. http://www.usa.philips.com/c-m-li/Vision-led
got mine at Farm & Fleet
The idle speed no longer changes at idle with brake release/apply due to reduced load.
the picture of the bike is with regular bulb in top left and other 5 are LED. Center under license is the Zevos, corners are Visions
OldNewbie is offline
post #8 of 22 (permalink) Old 12-07-2015, 09:32 PM
OldNewbie's Avatar
Year: 2003
Make: GL1800
Model: Wing
And with brakes on after ALL leds installed
post #9 of 22 (permalink) Old 12-09-2015, 04:55 PM
SilverDave's Avatar
Model: '85 GL1200 Aspy
GL1200's have even LESS light at the rear , and I once had friend rear ended on his 1100.
I used two 50 LED light strips ( JC Whitney , I think ) at about $14 ea. , coupled to the "Back off " flasher unit . One mounted high , at bottom of Top box, and one mounted low, near license plate .
They flash alternately with top box lights when brakes are applied . It looked pretty good to me.
But once , on an evening group ride , the Winger behind me rode up and said,
" Those are really , really annoying !!" ( bright, draws ones attention , etc )
.......so after THAT comment, now I think they are excellent .
I think Flashing LED's are much better than continuously burning , at least for increasing visibility .
And now that I have switched my front 55/60 watt headlight for a 30 watt HID unit.. the light bars seem to burn even brighter .
SilverDave
SilverDave is offline
post #10 of 22 (permalink) Old 12-09-2015, 05:13 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
At my three Walmarts they have Pilots in white, red and orange in different bulb types. After they were in stock for a while some of the designs were changed, I got the ones with more LEDs per bulb. My 750 needed white in the brake/tail light because of the license plate light, still pretty good in the daylight.
Scott
Searching for saddlebags Brandalou General Motorcycle Discussion Forum 2 08-09-2013 04:00 PM
searching the site oharaLTD Miscellaneous Forum 6 08-13-2010 10:01 PM
Rear Turn Light and Brake Light dvaught Goldwing Technical Forum 2 05-28-2009 02:59 PM
after searching... still wonder... UbarW Goldwing Technical Forum 7 04-29-2006 07:31 PM
Searching for straight 77GL1 Goldwing Technical Forum 21 11-04-2005 09:56 PM
