Hard Starting when cold - Steve Saunders Goldwing Forums
  • 1 Post By CaptainMidnight85
post #1 of 10 (permalink) Old 01-04-2016, 02:52 PM Thread Starter
Year: 1990
Make: GL1500
Model: Aspencade
Hi folks:
I would like your thoughts on my 1100. When the weather is above 60 degrees, the motor will fire up at the first bump of the starter with little or now choke. I give it a slight chock to warm her up and we are good to go.
Once the temperature drops below 50 degrees, she seems hard starting. If I give it chock, it turns over but won't fire. If I don't give it any chock, it fires right away but then dies. I try to give it slight chock but it almost seems like an all or nothing deal when trying to start it. I usually have to keep bumping the starter until it starts and barely keeps running. If I try to give it some gas, it will die. I usually have to get it to start and just wait a minute or two for it to warm up before I can give it gas and have it respond without dying.
Relating to this, when out riding during the summer, it will stumble when I give it gas went running around 50 MPH and it feels like it it is missing or fuel starved. When I set the valve clearance, I noticed the front right cylinder appeared to be running richer than the other three cylinders. I bought a kit but having balanced the carbs yet but that is on my list for this spring.
Would the carbs be causing these issues? Or this there something else I am missing? I would appreciate your thoughts.
Dave in Pierre, SD
dvoeltz is offline
post #2 of 10 (permalink) Old 01-04-2016, 03:14 PM
Roadyrider's Avatar
Year: 1986
Model: Aspencade, 86000 miles
I'm wondering if your choke is working all the way. I know my 1200 needs full choke in cold weather.
Roadyrider is offline
post #3 of 10 (permalink) Old 01-04-2016, 03:31 PM
to me, it sounds like it is jetted too lean.
this contributes to not wanting to run when first started, and also to not having enough power in the summer.
make sure the Accelerator Pump is working... twisting the throttle opens the air passage a bunch, and if there is no fuel squirted into the throat, it will sputter and die when cold, and stumble when warm.
post #4 of 10 (permalink) Old 01-05-2016, 12:51 PM Thread Starter
Year: 1990
Make: GL1500
Model: Aspencade
I think the chock is working because it seems to work fine when it is warm as the RPM's increase as I pull it back. But it is weird when I fully engage the chock when trying to start when it is cold that I get zero firing of the engine. It only fires with the chock fully disengaged. I'm wondering if a carb rebuild is in order?
I'll check the Accelerator Pump to see if that is a problem. Thanks for the suggestion John!
dvoeltz is offline
post #5 of 10 (permalink) Old 01-05-2016, 01:09 PM
It is not.
An indicator that is useless in the cold.
Because the fuel circuit(s) are plugged.
An indicator that fuel is not passing through the carburetor(s) properly.
Absolutely.
A disassembly for inspection is in order as a first step to correcting the problem of the choke not functioning properly.
CaptainMidnight85 is offline
post #6 of 10 (permalink) Old 01-05-2016, 01:44 PM
mrtwowheel's Avatar
Model: 1986 GL1200I
Seafoam, 1/2 can to a full tank of gas. New plugs, new spark plug caps, cut the plug wires back 1/4"-1/2" before screwing on new caps.
Scott
Send lawyers, guns and money
1975 GL 1000, Fermenting
mrtwowheel is offline
post #7 of 10 (permalink) Old 01-05-2016, 01:52 PM
...a preventive maintenance step. This won't fix his problem.
ALL good advice here.
tire joe likes this.
post #8 of 10 (permalink) Old 01-06-2016, 10:02 PM
mike@mikeblakeney.com's Avatar
Model: GL 1500 SE
I have learned that my 97SE fires when i get off or let go of the starter button. So I give it short bursts with the starter choked or not. Don't know if that will help but thought I would throw it out there.
post #9 of 10 (permalink) Old 01-06-2016, 11:45 PM
if you would put in an AGM battery, it would start before you could get your finger off the button almost.
it is the wet cell batteries that don't hold up their surface charge.... they pull down to around 10.5 volts and the 1500s refuse to fire the spark plugs until you release the Start Button, then the battery jumps back to ~12V and it fires right up.
In my '94 and my '98, I installed AGM batteries and both of them would start while turning over.
post #10 of 10 (permalink) Old 01-15-2016, 08:19 AM
Year: 1987
Model: 1987 gl1200 aspencade
So assuming valves are in spec and compression is good, u likely will need the carbs cleaned. I've noticed my bike runs lean when cold too. I get just a slight sputter and intake spits a little when cold. In my case it's the ethanol making the bike just a tad lean. I'm thinking next time the carbs are out I might add bigger pilot jets and shim the needles. In ur case I would check the float hieght before putting it back together. If they are in spec don't mess with them as that's like opening Pandora's box
Well have fun
Ps the 1100 pilot jets are usually pressed in. Best way to remove them is to insert a screw into the and pull them out with pliers using the screw head
1987 goldwing aspencade
apsolus is offline
My GL1500 - Very hard to start when cold papasmurf Goldwing Technical Forum 2 03-22-2012 05:46 PM
1988 hard to start when it is cold oldsouthpaw Goldwing Technical Forum 27 10-01-2010 04:55 PM
1500 se hard starting when cold oldsouthpaw Goldwing Technical Forum 8 07-01-2010 11:15 PM
GL1200LTD hard starting when cold ortiger Goldwing Technical Forum 8 08-08-2009 07:54 AM
Hard Starting when cold/backfiring sockeye342 Goldwing Technical Forum 12 10-01-2005 05:17 PM
