Suspension help for GL1500SE - Steve Saunders Goldwing Forums
 9Likes
post #1 of 14 (permalink) Old 01-08-2016, 08:54 PM Thread Starter
Year: 1995
Model: GL 1500 SE
Send a message via Yahoo to RustyTraveler
I am a new Goldwing owner and have noticed that my Goldwing bottoms out on speed bumps. I live in Mexico where roads are generally bad. Is this normal or is my suspension bad? I appreciate you wonderful people. It would have been impossible for me to have a Goldwing here without you!
RustyTraveler is offline
post #2 of 14 (permalink) Old 01-08-2016, 10:04 PM
It is pretty likely the forks and the right rear shock need the oil changed/refilled and the springs are probably weak from age. You have tried increasing the air pressure I assume?
RustyTraveler likes this.
post #3 of 14 (permalink) Old 01-08-2016, 10:24 PM Thread Starter
Year: 1995
Model: GL 1500 SE
Yes I have increased the pressure but it did not seem to make much difference. Oil changed? I assume there must be some info on that in the forums.
post #4 of 14 (permalink) Old 01-08-2016, 11:02 PM
NVSB4's Avatar
Model: 96 GL1500SE
Try this link for the rear shock and this one for the front.
It's never too late to have a happy childhood.
Red=All bikes Blue=Wings
Chris
NVSB4 is offline
post #5 of 14 (permalink) Old 01-08-2016, 11:55 PM
when you open those two links up, I highly suggest that you do a Right Click. "Save Page AS: HTML
that will download the entire page onto your laptop/PC...
Now if it is a laptop, you can carry it out to the garage and you have everything you want, including all the pictures, right at your finger tips...
AND, you will NOT need a WiFi/Internet connection to view it...
Aloha Tom and RustyTraveler like this.
post #6 of 14 (permalink) Old 01-09-2016, 08:56 PM
keithg64's Avatar
Model: GL1500SE
Plus on the rear shock oil. I just changed mine for the first time. It had about 40 ml in it and it requires 140ml. It's an easy job. I also changed the left side stock spring over to a progressive spring over shock.
keithg64 is offline
post #7 of 14 (permalink) Old 01-10-2016, 07:44 AM
Trike Master
tfdeputydawg's Avatar
Model: 06 levelIII/Hannigan
Pretty sure, as others have said, suspension rebuild is needed!
Take a look at the Mono-tubes for the forks!
tfdeputydawg is offline
post #8 of 14 (permalink) Old 01-10-2016, 08:43 AM
Year: 2006
The 1500 needs pretty much pressure in the rear suspension , around 75 psi was the best on mine , - it dosnt button out so eaysily and even have a better ride in the corners with less wobless .
SMEDEN(=the blacksmith) is online now
post #9 of 14 (permalink) Old 01-10-2016, 10:59 AM
NVSB4's Avatar
Model: 96 GL1500SE
Wow, 75 psi is real high.
The Owners manual says that max should be about 57 psi.
Chris
NVSB4 is offline
post #10 of 14 (permalink) Old 01-10-2016, 04:18 PM
rgmr250's Avatar
Model: 97 gl1500 SE
I put progressive suspension 416 rear air shocks in my 97 and racetech front springs. When two up i run close to 80 psi in the rear but the progressives are rated at max 100psi.
Current rides:
2010 Husqvarna TE250
2015 Kawasaki Ninja 650
2008 GL1800 with bagger kit
1997 GL1500SE
rgmr250 is offline
Suspension Goldywing Goldwing Technical Forum 5 09-21-2015 08:00 PM
GL1500SE elpuas Goldwing Technical Forum 2 06-03-2008 10:36 AM
Suspension bigoldguy Goldwing Technical Forum 8 07-21-2007 11:15 PM
New GL1500se ThunderBats General Motorcycle Discussion Forum 32 02-10-2007 10:43 AM
Suspension beachbuddy0253 Goldwing Technical Forum 7 05-06-2006 12:29 PM
