1993 GL1500SE Fuel Pouring - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 01-12-2016, 12:59 PM Thread Starter
i am working on a 1993 gl1500se. once you start this bike it will puor fuel out of the overflow tubes. i have removed carbs and cleaned. still leaked. i removed again and installed carb kit. still leaked. replaced carb and still leaking. i have checked fuel flow and i have a flow of 2400cc per min. book just says min of 640cc per min. i am looking for any help. i normally work on v-twin and have never run accross a fuel leak i cant stop. but i am stumped. FYI every time carbs wre removed they were cleaned in a sonic cleaner.
Yagerbomb85 is offline
post #2 of 7 (permalink) Old 01-12-2016, 03:13 PM
It aint rocket science
DriverRider's Avatar
Model: The best
Check fuel pump pressure, normal for the 1500 is 1.5 psi.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is online now
post #3 of 7 (permalink) Old 01-12-2016, 03:17 PM Thread Starter
i do not have a pressure tester that low
post #4 of 7 (permalink) Old 01-12-2016, 03:20 PM Thread Starter
i do know the pressure is less then 5lbs. that is where my tester starts and it did not move the needle
post #5 of 7 (permalink) Old 01-12-2016, 03:58 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Only a few things that will cause fuel to dump outta the overflow:
  1. Float level set too high
  2. Damaged or incorrect needle/seats not allowing proper sealing when the floats are up
  3. Too high of a fuel pressure (overcoming the normally adequate sealing of needle/seat)
  4. Fuel is actually coming out of the bowl drains and not the overflow (sometime folks forget to close the bowl drains and confuse the fuel source)
satan is offline
post #6 of 7 (permalink) Old 01-12-2016, 10:45 PM
5. Something not assembled correctly, or debris stuck in needle and seat area.
redwing52 is offline
post #7 of 7 (permalink) Old 01-16-2016, 03:00 PM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
I honestly think the 'high pressure' diagnosis is bogus. The area involved where the valve sits is so small that the force trying to push the valve open is miniscule. Dirt on the seats however.......
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
windhshield 1993 GL1500SE Teri Mundy Goldwing Technical Forum 2 09-22-2013 04:50 PM
Fuel pouring into GL1000 exhaust sbcgos Goldwing Technical Forum 8 08-05-2013 06:53 PM
1993 Goldwing GL1500SE for Sale asigetic For Sale/Wanted Forum 6 07-25-2012 06:20 AM
Help, which relay 1993 GL1500SE? thibbledorf Goldwing Technical Forum 5 04-07-2010 07:21 PM
How to replace front speakers on 1993 GL1500SE TXGrasshopper Goldwing Technical Forum 9 02-24-2010 05:48 PM
