Changing engine size 1200 => 1100 frame? - Page 31 - Steve Saunders Goldwing Forums
 37Likes
post #301 of 579 (permalink) Old 03-12-2016, 02:47 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Originally Posted by ekvh View Post
And I have now joined the bent-rod club for the leaky float- hydrolock issue. I have had hydrolock a few times now, but the last one, I hit the starter and the motor had about what sounded like a full rotation and then a metallic whack when it stopped. I pulled plugs, rolled it over, restarted and finished the summer, but it seemed to have a little vibration at idle, and I blew a headgasket which was between the 1-3 cylinders. Pulling the heads I happened to notice #1 piston does not come out proud of the block. It stays in about 0.040" while the others are about 0.040" proud of the block deck. I have an 87 to replace it with, but it's deck is off a bit. I think I have to get it shaved or I'll just crack the heads by the oil galley return.
So check those float valves and turn the petcock off.
That is why I have a N/C fuel solenoid that opens with the key on.
JeffMayfield is offline
post #302 of 579 (permalink) Old 03-13-2016, 04:58 PM Thread Starter
big PIA
MysticFour's Avatar
Drained the oil and put new filter in and fresh oil, got the engine cranking over to check compression, I know that should be done when warm but just checking it anyhow, 1 cyl at 105 and other 3 at 120.
Seems like decent pressure for something that has been sitting for a couple months.
Put plugs into the wires and watched them while cranking engine, spark looked a lil weak but it was there, now I need to get gas and it should fire up
MysticFour is offline
post #303 of 579 (permalink) Old 03-13-2016, 10:58 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Hope you have the battery on a tender/charger after all that cranking.
So you have the 1100 carbs on the 1200 engine in a 1100 frame.
A short video of the first start up would be great.............................
Do you have coolant in yet?
Don't want to blow the head gaskets.
post #304 of 579 (permalink) Old 03-14-2016, 06:09 AM Thread Starter
big PIA
MysticFour's Avatar
Haven't gotten a fuel pump yet, battery has been dead for 2 years, filled with water cause it was dry, added a car battery with cables cause charger did nothing, put car battery on charger and cables to bike battery and bike finally taking a charge haven't added radiator back to bike yet, won't run bike but a min or so without it.
Still working up to getting it started
post #305 of 579 (permalink) Old 03-14-2016, 05:43 PM Thread Starter
big PIA
MysticFour's Avatar
Brought home 2 gallons of gas, put in bike and just my luck, barely even with petcock so no gravity feed, really wish I had a fuel pump right now
post #306 of 579 (permalink) Old 03-14-2016, 10:31 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
If you got the coolant system buttoned up you could warm the bike up once it starts.
Just saying....................
post #307 of 579 (permalink) Old 03-14-2016, 10:33 PM
He just wants to make sure it runs before buttoning up everything, don't blame him. Won't hurt it to run a couple minutes with no cooling system.
Ken Bergen and MysticFour like this.
post #308 of 579 (permalink) Old 03-14-2016, 11:09 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I understand that.......
If he really just wanted to start the bike why not hang a small bottle on the handle bars so he could gravity feed the fuel.
post #309 of 579 (permalink) Old 03-15-2016, 08:17 AM Thread Starter
big PIA
MysticFour's Avatar
I would have done that had I realized 2 gallons was not going to be enough in tank, plus I don't think I have a bottle to do it with
post #310 of 579 (permalink) Old 03-15-2016, 11:54 AM
I've been running a Mr. Gasket electric pump for a few years or more.
Though I should probably have some sort of safety shut-off for it, I don't. It turns "ON" with the key. I don't have a separate fuse for it. I think I wired it to the accessory terminals.
I've yet to have a problem of any kind from this electric pump.
And you probably won't unless the bike gets tipped over with the switch on or has a leaky needle valve and the key gets left on.
It hydro-locked once. No fault of the electric pump.
I suppose a tilt switch w/relay would work should it ever fall over while idling.
I just don't see the need for it ...for me.
CaptainMidnight85 is offline
1200 into 1100 frame..... OK??? Cyclebuster Goldwing Technical Forum 3 03-16-2014 12:30 AM
Is it posible to put in a 1100 engine in to a 1000 GL frame ? Lakvakk Goldwing Technical Forum 14 06-15-2011 07:59 PM
Is this an 1100 engine in a 1000 frame? wpgfire Goldwing Technical Forum 16 11-29-2009 04:26 PM
Will a GL1200 or 1100 engine fit in a GL1000 frame johnnymac Goldwing Technical Forum 2 04-04-2009 11:58 AM
Would that 1100 engine fit in a 1200 frame gyro_ca Goldwing Technical Forum 6 03-26-2009 08:28 AM
