Changing engine size 1200 => 1100 frame? - Page 5 - Steve Saunders Goldwing Forums
 37Likes
post #41 of 579 (permalink) Old 02-06-2016, 09:05 AM
ekvh's Avatar
Model: 77/83/85/yup, all of 'em in one
Master cyl from a 1500 will also work for clutch and appear more plentiful and cheaper on eBay. Not sure if 1500's ever went to bigger than 3/4" bars. Maybe in later years.
ekvh is offline
post #42 of 579 (permalink) Old 02-06-2016, 10:13 AM Thread Starter
big PIA
MysticFour's Avatar
what size is the bar on the 1100?
MysticFour is offline
post #43 of 579 (permalink) Old 02-06-2016, 10:24 AM
7/8"
CaptainMidnight85 is offline
post #44 of 579 (permalink) Old 02-06-2016, 02:55 PM
ekvh's Avatar
I had a 3/4" Brain fart, I think they're all 7/8".
ekvh is offline
post #45 of 579 (permalink) Old 02-06-2016, 09:06 PM Thread Starter
big PIA
MysticFour's Avatar
Well engine has been paid for, now waiting for it to be shipped. will need to try getting gasket for back of motor, electric fuel pump and hydraulic hose and master for the clutch if I am gonna use the 84 clutch.
Hope it won't be terrible to put in
post #46 of 579 (permalink) Old 02-07-2016, 05:27 AM
Silverado6x6's Avatar
Year: many years, two different continents.
Model: 2035 GL3500 Intercontinental
Here is my 83, still in storage, the 84 is under a tarp, bought the 84 ftom a Harley shop for $50, its just frame and motor, they were trying to make a chopper out of it.
So this 83 did run, but poorly, it might still have that motor left in it, i'm not too terribly conserned about it running well, if it rolls and can stand upright it might only be good for the annual custom bike show here in Alaska, they have almost no Goldwings in it year after year.
Silverado6x6 is offline
post #47 of 579 (permalink) Old 02-08-2016, 05:59 PM Thread Starter
big PIA
MysticFour's Avatar
Originally Posted by westgl View Post
To do a GL12 engine swap into a GL11 frame.
You need to pull engine(s) Mr obvious here.
The rear trans cover, and Clutch cover are interchangeable between the 84' GL12 Only, and the GL11 engines.
Then pull the rear engine cover (this will require a new rear cover gasket think they are about $26.00) then switch the output shaft from your GL11 into your GL12 Engine, the output shaft just pulls out and slip in no tools required.
You could replace the output shaft seal, while you have it apart.
And now is a good time to decide if you want to replace stator or not.
Then you can use the GL11 drive shaft in the GL11 frame.
Looking forward to doing this In a couple weeks I hope if I can get the rest of the parts and gaskets I need
post #48 of 579 (permalink) Old 02-08-2016, 06:06 PM Thread Starter
big PIA
MysticFour's Avatar
I see westgl has not been on here since October, would like to pick his brain a little on the subject
post #49 of 579 (permalink) Old 02-09-2016, 02:26 PM
ekvh's Avatar
He's around now and then. I think you'll be very happy with an 84 in and 83 bike.
ekvh is offline
post #50 of 579 (permalink) Old 02-09-2016, 05:11 PM Thread Starter
big PIA
MysticFour's Avatar
I see a set of 84 carbs on ebay for 40 dollars, very tempted to grab them.
http://www.ebay.com/itm/Honda-gl1200...5WjW9h&vxp=mtr
They look fairly clean to me and don't think I will ever beat that price.
1200 into 1100 frame..... OK??? Cyclebuster Goldwing Technical Forum 3 03-16-2014 12:30 AM
Is it posible to put in a 1100 engine in to a 1000 GL frame ? Lakvakk Goldwing Technical Forum 14 06-15-2011 07:59 PM
Is this an 1100 engine in a 1000 frame? wpgfire Goldwing Technical Forum 16 11-29-2009 04:26 PM
Will a GL1200 or 1100 engine fit in a GL1000 frame johnnymac Goldwing Technical Forum 2 04-04-2009 11:58 AM
Would that 1100 engine fit in a 1200 frame gyro_ca Goldwing Technical Forum 6 03-26-2009 08:28 AM
