'82 GL1100 Corpse Needs Your Help - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 13 (permalink) Old 02-18-2016, 06:39 PM
lyleapgmc's Avatar
Remove the timing belt covers and check the condition of the belts. Then carefully check the timing of the cams. Take the belts off and toss them. Replace with new. If one or both of the cams are out of time the resistance you feel may be a piston hitting a valve held open by a cam.
Getting oil or solvent all around a cylinder is difficult. A length of tubing on a spray can might help. Try piercing radial holes in the tubing and plugging the end so the spray goes to the cylinder walls rather than straight out the end of the tube.
I would not pull the heads unless there is some definite indication of a failed head gasket. If it ain't broke don't fix it.
Most starter issues are cured by a thorough cleaning and replacement of the brushes. Clean, corrosion free wiring connections are vital to good starter and charging system performance.
Check the three yellow wires from the stator. If the connector hasn't been replaced do that with solder and shrink tubing. If it's already been done, redo it with solder and shrink tubing.
Good luck,
Lyle, President of the Use Punctuation, Paragraphs, Capitals and Non Use of Acronyms Club.
I'd sure love a $175,000 a year part time job with benefits like member of Congress have.
lyleapgmc is offline
post #12 of 13 (permalink) Old 02-18-2016, 11:22 PM
Folks,
I should not have posted the IP info, I have deleted all references to location, and this is the end of that story. No comments on location.
this has caused toolbox007 a lot of grief..... he was on a company system that cannot be identified, so this is the end of the location issue.
I emailed him an apology and hopes he comes back.
post #13 of 13 (permalink) Old 02-19-2016, 08:26 PM
Year: 1981 1100I [being triked now] 1995 1100 ACE & triked out 1100A
Make: Hondas
Model: 1981 1100i
John, A great job on your last post, Makes me really feel good about this site and the way that it was handled,,,,,, Charlie
AZgl1800 likes this.
Charlie in nc is offline
New guy with '82 GL1100 Corpse to resurrect... toolbox007 New Members Introduction Forum 9 02-20-2016 07:28 PM
Gl1100 back rack sissy bar compatible with gl1100 auctioneeral General Motorcycle Discussion Forum 2 08-03-2015 07:54 AM
F/S GL1100 Std and GL1100 Interstate Right Front Brake Rotor newday777 For Sale/Wanted Forum 0 03-26-2014 02:33 PM
Brake rotors of a 1981 GL1100 and a 1982 GL1100 interchangable dgreene Goldwing Technical Forum 10 08-12-2010 10:13 AM
Corpse on a Motorcycle Hawggy Miscellaneous Forum 4 04-30-2010 03:13 PM
