Weird Tail Light Story GL1500 - Steve Saunders Goldwing Forums
 2Likes
post #1 of 13 (permalink) Old 03-04-2016, 04:53 AM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
Okay... i had to take half the bike apart to replace the turn signal assembly. I assembled everything testing to make sure everything stayed working as I went.
Bike ran... lights worked... blinkers fixed.
The yesterday this pulls up along side me at a light and says my tailights are out. Sure nuff it's true... brake lights are fine... no tails. Make it into work and dismount to see if its a fuse... they're working.
Afternoon comes... go to ride home. Not working.
Get home... they're working...
Tear half the bike apart again...everything connected properly. Tailights NOT working... can't find a problem.
Start bike... pump brakes a bit to check the brake lights... then the tail lights come on.
Shut bike off. Start it again. No tail lights. Pump the brakes... tail lights come on.
let bike sit over night... engine cold.
Come out to test it again... pump brakes... brake lights work... they have never been the issue. Tail light NOT working.
So... the bike has to be running and warm... and by pumping the brakes a time or two I can the the taillights to work.
And thoungts on what the heck might be wrong?
us385south is offline
post #2 of 13 (permalink) Old 03-04-2016, 06:11 AM
RB
RB's Avatar
Send a message via AIM to RB
Maybe a common ground that gets better connectivity when the brakes are applied..?? shot in the dark..
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #3 of 13 (permalink) Old 03-04-2016, 06:15 AM
Im thinking probably a bad ground. Have you looked at the large connectors on each side of the frame under the seat?
post #4 of 13 (permalink) Old 03-04-2016, 06:24 AM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
Dave...
Off to work in the truck now. This evening, was going to have a look at every connector I can find... with special emphasis on the one I might have fiddled with replacing the turn signal harness. I am soooo tired of working on this bike. Two floods... two sisters dead... no summer tour... and now Spring ride is only a week away... it has been a very bad tear for me. If I don't get to ride soon I am going to explode.
post #5 of 13 (permalink) Old 03-04-2016, 07:30 AM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Tail Lights
What model is your bike, Interstate, Aspencade or SE...??
You have tail lights that are powered from two different sources.
1. Trunk tail lights are powered from the relay # 3.
Note: Any other lights not working.....?? Relay # 3 powers a lot of lights etc.
2. Saddlebag tail lights are powered from the ignition switch.
Which ones are not working..??
Or are both of them not working..??
You only have one ground wire running to the rear of the bike. It grounds the tail, brake, turn signal and licenses plate light. You say the brake lights always work......!!
You need to narrow down which tail lights are not working then go from there.
Check the "green" ground wire at the 22-pin connector under the seat (left side).
Check the "green" ground wire where it connects to the radiator. That's the ground source for the rear lights.
DBohrer is offline
post #6 of 13 (permalink) Old 03-04-2016, 10:23 AM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
DBoher... helpful advice...
1996 Aspencade Pearl Blue, the most rare, and therefore most expensive color
NONE... of the tail lights work... nor do the dash lights...
Unless of course they DO work...
Gonna go after it tonight... when I come in from surviving my day teaching middle school.
By way of green wire that connects to radiator... you are talking about the one that comes out of the stereo bundle under the shelter, right?
T
Thanks
post #7 of 13 (permalink) Old 03-04-2016, 11:50 AM
DBohrer's Avatar
Year: 1967
Tail Lights
If you don't have any tail/running lights on the trunk or saddlebags, then I don't think you have a power issue. They get power from two different sources (ignition switch and relay # 3).
I suspect you have a ground issue.
Do this test........
At the White 22-pin connector under the seat (left rear side), connect a jumper wire from the Green (ground) wire to a frame ground (or negative battery terminal).
Do you have rear tail/running lights now.....???
Also clean that connection where the Green wire is attached to the radiator.......!
DBohrer is offline
post #8 of 13 (permalink) Old 03-04-2016, 12:16 PM
So now we have the rest of the story. How about the front marker lights, position lights etc?
post #9 of 13 (permalink) Old 03-05-2016, 07:01 AM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
DBohrer...
Cleaned all the grounds... both the ones that connect to the radiator and the one(s) bolted with the 10mm under the seat.
Ran the jumper test on the left side pin connector... no go!
Dave0430...
Have pulled the entire shelter apart again... no missing plugs... even undid the ones I disconnected in the turn signal repair just to check for broken or bent pins.
"Help me Obi Wan Kenobi, your my only hope!"
Princess Leia, A long long time ago
siouxindian likes this.
post #10 of 13 (permalink) Old 03-05-2016, 11:12 AM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
Okay... found the problem... the relay... imagine that?
Completely unrelated to my turn signal repair... just a simultaneous coincidental failure of the relay.
Duh...
Full Tupperware party underway here!
T
'97 GL1500 SE Auxilliary Tail/Brake Light Bluewaterhooker0 Goldwing Technical Forum 5 01-04-2014 05:56 AM
No head light or tail light, GL1500 88MTRTRIKE Goldwing Technical Forum 3 08-24-2012 03:04 PM
GL1500 Tail light wiring PLODDER2 Goldwing Technical Forum 7 08-09-2012 08:56 AM
GL1500 Spoiler Stop/tail light. davepyer Goldwing Technical Forum 7 05-08-2012 05:58 PM
GL1500 Tail light problem midwing Goldwing Technical Forum 4 04-18-2011 01:39 PM
