Radiator flush out - Page 24 - Steve Saunders Goldwing Forums
 58Likes
post #231 of 387 (permalink) Old 05-10-2016, 05:35 PM
Year: 94
Model: 1500 SE
I dont know what product you are using BUT most sealing paste or glue type material is to be used with the correct gasket, giving an extra layer of protection
With orings being cheap, and liable to fail after you have touched it~ replacement is wise- In my opinion
redwing52 and JeffMayfield like this.
Aloha Tom is offline
post #232 of 387 (permalink) Old 05-10-2016, 08:40 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
http://www.westernhonda.com/fiche_se...84&fveh=132497
JeffMayfield is offline
post #233 of 387 (permalink) Old 05-10-2016, 11:01 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
Originally Posted by Mr Magic Fingers View Post
No problem Crimson Wing. I just wanted to make sure.
Carry on. Keep up the good work.
Tim
thanks tim! ill order the coolant pipe joint gasket and o ring. this is the fourth order from wsternhonda i am going to make and i pay $15 in shipping every time, this is really adding up haha. I hope i wont be needing any more parts. now this brings up another question, can i put the head back on without putting the pipe back on? or can i just put the head on and then put the pipe on when the gasket comes?
crimsonwing is offline
post #234 of 387 (permalink) Old 05-10-2016, 11:51 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
correct
Speaking of heads how do they look
post #235 of 387 (permalink) Old 05-11-2016, 01:31 AM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
correct
well i havent even had a chance to clean them yet so they are still all yuky amd carbon covered and what not, but i have the day off tomorrow and im gonna scrub scrub scrub! Before i put the heads back on though i would like to know if anyone recommends new valve stem seals based on the pictures posted, any ideas?
post #236 of 387 (permalink) Old 05-11-2016, 02:04 AM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
On your way home buy a tub and k-1.
Soap and water just ain't going to cut the grease I don't care what the Dawn bottle says.
post #237 of 387 (permalink) Old 05-11-2016, 05:26 AM
Mr Magic Fingers's Avatar
Lightly lube those o-rings (#15 above) with a little SILICONE lube and not an oil based grease or oil when you reinstall them and make sure you use NEW O-rings.
They can easily be pinched or rolled/twisted in this application and cause a leak. You will only find this out AFTER you start the bike up and it gets warm.
Make sure the mating parts are clean. Inspect closely after you install.
Tim
JeffMayfield and Aloha Tom like this.
____
Please visit
Mr Magic Fingers is offline
post #238 of 387 (permalink) Old 05-11-2016, 11:35 AM
Year: 94
Model: 1500 SE
If you have nowhere to safely and properly clean the heads- take them to a machine shop!
They have a dunk tank filled with solvent that will return the parts looking brand new
Can also bead blast parts as needed to freshen surfaces ie: remove stuck-on gasket material
When you cant diy- let a PRO do it!
post #239 of 387 (permalink) Old 05-11-2016, 12:09 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
Tim
okay, should i use the silicone lube for all the o rings on the water pump cover too? hmmm, is k 1 or any other solvent save in valve stem seals? also i found this on another forum, what y'all think?
"It seems best to CAREFULLY chase any and all threads to be sure at reassembly. I have seen head bolt and stud holes filled with junk especially at a head gasket change since the gasket was compromised it is possible for minute amounts of coolant and moisture to migrate the entire length of the bolt/stud with the many heat cycles before total gasket failure.. Engine oil and coolant can do the same on any exposed fastener."
post #240 of 387 (permalink) Old 05-11-2016, 04:58 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
i got both heads clean!!All i used was hot running water, ajax dish soap and 3 mini brushes. it took me a few hours, they are not factory new, but they are soooooooooo much cleaner than before. I got the hot running water and scrubbed it down with soap and a nylon mini bush. i did this for a while until i thought it was time to use the brass brush. after that i finally used the stainless steel mini brush and extra soap and voila!! not bad eh? i also made sure to keep the gaskets on so i would not accidentally scratch the mating surfaces. now to take the gaskets off and check for warpage, if so ill resurface them with my 800 grit sandpaper, then 1000. after ill sand the block and pop the heads back on!!
radiator flush "doc mccoy" Goldwing Technical Forum 3 05-07-2014 08:55 PM
goldwing 1200 radiator flush kmjw Goldwing Technical Forum 8 06-08-2013 12:27 PM
GL1500, flush n fill radiator bking Goldwing Technical Forum 5 10-31-2011 11:32 AM
1500 radiator flush SpiderBob Goldwing Technical Forum 2 06-10-2009 10:09 PM
radiator flush? hockeydad33 Goldwing Technical Forum 24 07-08-2005 12:16 PM
