Radiator flush out - Page 29 - Steve Saunders Goldwing Forums
 58Likes
post #281 of 387 (permalink) Old 05-15-2016, 04:14 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
oops forgot to post the resurfaced heads
crimsonwing is offline
post #282 of 387 (permalink) Old 05-15-2016, 06:18 PM
Mr Magic Fingers's Avatar
Looks good from here.
Make sure you clean the debris from the cylinder wall cavity. You don't want that in you cooling system.
Also, you should pick up a can or two of non chlorinated brake cleaner and clean your engine. You not only will highlight your hard work and look great, it will also be clean so that you can trace any leaks that develop if things didn't go to plan.
Try to get your external engine parts as clean as you can.
As far as exhaust doughnuts go, they are copper and get crushed and squished into place. Most times it looks like it is part of the head. you will have to gently pry them out with a flat head screwdriver.
It would be difficult to run them bike without them and not notice that they were missing so they must be in there.
Make sure you put anti-seize compound on the exhaust studs so the next time the nuts will come off easier.
Tim
____
Please visit
Mr Magic Fingers is offline
post #283 of 387 (permalink) Old 05-15-2016, 07:20 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
Tim
i will make sure to clean both the head cavities and engine aread. i have two cans of non chlorinated brake cleaner so im good to go! i got the exhaust donuts off, i just need to put the cam seals in, thanks!!
post #284 of 387 (permalink) Old 05-15-2016, 07:33 PM
On the camshaft seals, if the OD is metal they go in dry, if not a light coat of engine oil to the OD and bore.
The sealing lips must be lubricated, oil or grease.
Ken Bergen is offline
post #285 of 387 (permalink) Old 05-15-2016, 08:21 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
can i just pull em out? or do cams need to be removed?
post #286 of 387 (permalink) Old 05-15-2016, 09:34 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Cams must come out.
Did you find the shift shaft seal location?
JeffMayfield is offline
post #287 of 387 (permalink) Old 05-15-2016, 09:47 PM Thread Starter
Year: 1984
Make: honda
Model: GL1200 I
Cams must come out.
alright, ill take cams off. shift shaft seal is where the foot shifter joins the engine right? it looks like the seal i got in the mail so must be it. now, i just notice for each head, two of the six screws are longer, do these ones go in the dowel pin holes?
post #288 of 387 (permalink) Old 05-15-2016, 09:55 PM
Let us know before you put that shift seal in.
post #289 of 387 (permalink) Old 05-15-2016, 10:25 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
First of all you need to remember there are 7 head bolts for each head.
More than one head has been cracked by forgetting about that tiny bolt
Also you don't want to over torque that tiny head bolt.
Have you screwed the head bolts back into the block to verify each bolt can be turned by hand beyond what is needed to clamp the heads on??????
If you are unsure where bolts of differing lengths are suppose to be placed then start with the short ones and it will become evident where the long ones go. Slide them in the head they should be even on the block side.
The clean up looks good so far.
post #290 of 387 (permalink) Old 05-15-2016, 10:32 PM
Refer to your manual for the torque patterns on those head bolts. It is very important you get that right.
radiator flush "doc mccoy" Goldwing Technical Forum 3 05-07-2014 08:55 PM
goldwing 1200 radiator flush kmjw Goldwing Technical Forum 8 06-08-2013 12:27 PM
GL1500, flush n fill radiator bking Goldwing Technical Forum 5 10-31-2011 11:32 AM
1500 radiator flush SpiderBob Goldwing Technical Forum 2 06-10-2009 10:09 PM
radiator flush? hockeydad33 Goldwing Technical Forum 24 07-08-2005 12:16 PM
