Refurbishing a 1998 Aspencade - Page 2 - Steve Saunders Goldwing Forums
 2Likes
post #11 of 23 (permalink) Old 04-12-2016, 04:38 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
I recommend you check the exhaust chamber connections, two in front for exhaust pipe and two in rear for muffler. Check for a crack on the metal connectors or a bad chamber gasket, and repair or replace while the exhaust covers are removed.
I have just completed these checks and repairs, and re-painted exhaust covers (r176c), refreshed heat shields. If you need any information on these issues I may share my experiences.
Erdeniz Umman is online now
post #12 of 23 (permalink) Old 04-12-2016, 08:47 AM
(Rick Sheeley GWRRA)
kgypsy's Avatar
Year: 1995
Make: Honda (of course!)
Model: 1995 GL1500 SE Anniversary Edition
TNRick,
Don't forget all my rebuild posts and videos from the last two years, and feel free to email me directly If I can advise/help. I also have two full harnesses sitting in a box if you need replacement connectors, etc.
https://www.goldwingfacts.com/forums/...gl1500-se.html
Rick/KG
Rick Sheeley/King Gypsy
East Coast,USA
"The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge.." - Stephen Hawking
kgypsy is offline
post #13 of 23 (permalink) Old 04-12-2016, 06:40 PM Thread Starter
TnRickB's Avatar
Year: 1998
Model: Aspencade
Originally Posted by kgypsy View Post
TNRick,
Rick/KG
I had read through your entire rebuild when I was doing research on different things. Funny thing. I looked up a bunch of different items and your posts always came up. Did you get an honorary "Honda Certified Mechanic" out of your rebuild? Thanks for the info on the parts. A parts source is always good.
1989 Kawasaki 454
1987 Honda Super Magna
1984 Kawasaki Voyager
1992 Honda Goldwing Aspencade
2006 Suzuki Katana 750
2007 Harley Sportster 1200
1998 Honda Goldwing Aspencade
2012 Harley Softail Slim
TnRickB is offline
post #14 of 23 (permalink) Old 04-12-2016, 06:46 PM Thread Starter
TnRickB's Avatar
Year: 1998
Model: Aspencade
I have pulled both mufflers off and one of the headers (Shifter Side). They appear to be ok so far. I am considering pulling the other side just to check. I wanted to check them too. I saw some pictures of other collectors that just broke off when trying to get the pipes removed.
I have a question that you or others may be able to answer. Is there any advantage to painting the headers and the collector box to stall and prevent corrosion? Will it last or would it be a waste of time? Any suggestions for paint if deemed a good idea?
Erdeniz Umman likes this.
1989 Kawasaki 454
TnRickB is offline
post #15 of 23 (permalink) Old 04-12-2016, 06:50 PM Thread Starter
TnRickB's Avatar
Year: 1998
Model: Aspencade
Response to Mr Magic Fingers
I am still working through the operation of the website. I had to edit.
I am going to look for the product later this week. I think it will come in hand for a few items. The one good thing about doing things at home is getting new tools. I already have new air sockets, pliers... why not get a tub washer. We have a new harbor freight in town now. I will check them out.
1989 Kawasaki 454
TnRickB is offline
post #16 of 23 (permalink) Old 04-12-2016, 06:57 PM
Mr Magic Fingers's Avatar
When rebuilding my bike I did not paint the headers how ever I did paint the collector box with high heat paint.
It has not burn off and there are no rust spots on it. I did several coats with brush on Tremclad brand paint designed for wood stoves.
It dried for about 2 months before it ever got heated up. That was 4 years ago and looks like I put it on last month.
Highly recommended!
Tim
____
Please visit
Mr Magic Fingers is offline
post #17 of 23 (permalink) Old 04-12-2016, 07:09 PM Thread Starter
TnRickB's Avatar
Year: 1998
Model: Aspencade
I had not thought about wood stove paint. That might do the trick. I know the collector boxes are no longer available and viable ones are hard to find if you want to use the stock items. The one on my bike is in decent shape (I haven't pulled it off completely yet), but it is at the age that I need to do something that help prevent the corrosion. I think will plan on getting that painted. One more item on the "to do" list.
1989 Kawasaki 454
TnRickB is offline
post #18 of 23 (permalink) Old 04-12-2016, 07:32 PM
I sand blasted mine with glass medium and gave it a good inspection. It was in great condition. I was very thankful.
I wish there was a Harbour Freight in Maine. It would be worth a drive there to just look around!
Tim
____
Please visit
post #19 of 23 (permalink) Old 04-12-2016, 07:43 PM
As I sit here watching Cold Water Cowboys and reading through this site, I noticed in the flyer pack that came today, a Princess Auto flyer and in it is the parts washer on sale for $60.
Tim
____
Please visit
post #20 of 23 (permalink) Old 04-13-2016, 01:09 AM
The reason for the cracks on the collector is, probably the difficulty of removing mufflers or pipes from the chamber due to bad gaskets welded to the parts after some time. Then you will have to move the mufflers or pipes a lot to loosen and remove.
I have painted both the header pipes and the collector with a heat resistant (690 C or 1270 F) black spray paint. I removed the dirt and rust on the parts with a 150 grit sand paper first, then applied the paint directly, not using primer.
Here I want to note that, after painting, the parts should be exposed to heat (160-200 C or 300-400 F) for 1 hour to harden the lacquer coat, according to the instructions on the paint can.
1998 Goldwing Aspencade wayler For Sale/Wanted Forum 1 03-04-2012 01:55 PM
Refurbishing rocker covers Robin General Motorcycle Discussion Forum 16 08-11-2010 08:02 AM
refurbishing a plug cap RB Goldwing Technical Forum 2 11-24-2008 09:58 AM
1998 GOLDWING ASPENCADE elaj Goldwing Technical Forum 1 05-06-2008 07:44 AM
Refurbishing chromed parts glasgowing Goldwing Technical Forum 2 10-13-2007 07:41 AM
