83 GW Standard - getting hot - Page 2 - Steve Saunders Goldwing Forums
post #11 of 14 (permalink) Old 04-20-2016, 03:32 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
low speeds tends to make mc run hot,airflow below 40 or so isn't enough airflow and fan doesn;t really pull that much air,real test is what happens at about 50+
neoracer is offline
post #12 of 14 (permalink) Old 04-20-2016, 07:50 PM
Originally Posted by zoomjay View Post
I have many more reasons to trust my infrared gauge than my bike gauge... so, I suspect the bike one is bad...
How does one test the gauge... or should one simply get a new sending unit to put in??
You can test the sensor. @140f it should read 104 ohms, @185 f 43.9 ohms, @ 232f 20.3 ohms.
post #13 of 14 (permalink) Old 04-20-2016, 07:51 PM
Just another thought. When I'm test riding without the side plastics on each side of the radiator, I've noticed both my 1200's run a little hotter.
bruce p is offline
post #14 of 14 (permalink) Old 04-20-2016, 07:55 PM
Yes, I built an 1100 and thought I could do without the air scoops, I was wrong.
83 standard... or is it? zoomjay Goldwing Technical Forum 2 01-12-2015 06:40 AM
gl1100 with a full vetter HOT HOT HOT timbrains Goldwing Technical Forum 7 09-03-2010 10:30 AM
84 Standard Al Smith For Sale/Wanted Forum 0 09-27-2007 09:42 AM
GL1100i Hot Hot Hot! roytoy1 Goldwing Technical Forum 49 08-02-2006 10:22 AM
runs hot or says its hot wda-83wing Goldwing Technical Forum 14 06-22-2006 03:22 PM
