GL1500 starts after releasing button solved - Page 3 - Steve Saunders Goldwing Forums
 38Likes
post #21 of 25 (permalink) Old 06-30-2019, 03:20 PM
gipsy42's Avatar
Model: '93 GL1500 SE "Blue Angel"
Send a message via Skype™ to gipsy42
Update
Friday I finished the ignition mod; I would say that normally she was starting fairly good before; but now it fires like itís flying out, Iím really happy with it when tested in the garage.
I believe that we have to give some credit to those Japs that designed this machine, even when they didnít prevent the fact that weíll be using them 30 or more years after, LOL. The GLís were good designed but time is deadly thing on humans as well as in machines, theyíre no exceptions.
I agree with you about keeping modifications at the minimum, but as I look the schematic I believe the ECM is just grounding the coils to fire the plugs and mod at C54 wouldnít affect anything.
Yesterday I went out (even with some drizzle) riding for lunch to a friend place with other 25 GLís, and many of them were interested in this mod, so the bike took many starts up as they stand around and tried by themselves, it would fire really fast.
The surprise was that one SE í96 with original wiring (no Mods at all) was firing just as fast and good as mine. This makes me conclude that age isnít the same for everyone, LOL.
When Iíve had all TP stripped and wiring at sight, with fully charged battery I took some readings hooking a VOM between 55 A. fuse and low side of C54, turning the key ON it showed a voltage drop of 1.1 V, and during cranking the reading was 3.4 V; which means an astonishing 30% voltage drop.
Of course this is in my bike, which perhaps has aged more than others ROLOF.
If I ever find any more details (either good or bad) Iíll be posting them.
I hope this may help some others, should any of you have doubts, please donít hesitate and call me.
AZgl1800 and Erdeniz Umman like this.
Mario
And still riding...
I just regrets the things I haven't done.
gipsy42 is offline
post #22 of 25 (permalink) Old 07-03-2019, 06:10 PM
BLUTHUNDR31's Avatar
I'm having a minor issue with finding where the C54 connector is in relation to C57. If C57 is on the right side near the fan, is C54 also on that "connector bar"? Anyone have pictures of where C54 is located?
BLUTHUNDR31 is online now
post #23 of 25 (permalink) Old 07-03-2019, 06:36 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
C54 is located behind the right inner fairing panel. The one by your right knee when sitting on the bike.
Its a White 4-pin connector. You'll see the Black/White wire....!
Look at picture # 24....!!
File Type: jpg GL1500 Engine Control Module Connector.jpg (122.1 KB, 10 views)
gipsy42 and BLUTHUNDR31 like this.
DBohrer is online now
post #24 of 25 (permalink) Old 07-03-2019, 06:55 PM
Thanks DBohrer, , ,
Help me to get this through my lil pea-brain, , , ,
That white connector has a "male" (plug) and a "female"(socket). I need to cut the Blk/whi wire on the "male" (plug) side and connect it to the "trigger" side of the relay, , then I need to cut the Blk/whi wire on the "female" (socket) side and connect it to the 12V "power" side so the 12v from the battery is sent to the coils AFTER the ignition is on (which powers the "trigger" side) and closes the contacts for the 12volts to flow.
post #25 of 25 (permalink) Old 07-03-2019, 09:01 PM
DBohrer's Avatar
Year: 1967
You have a private message......!!
corkya and BLUTHUNDR31 like this.
My GL1500 starts when starter button released WIDETRAC Goldwing Technical Forum 13 04-30-2013 10:39 PM
84 Aspencade starts but no dash- or lights SOLVED!! RayJay1959 Goldwing Technical Forum 4 09-16-2011 04:48 AM
1500 Starts on button release jbacrawler Goldwing Technical Forum 30 07-29-2011 08:39 PM
GL1500 starts after release of start button ? red1500 Goldwing Technical Forum 14 04-30-2011 06:14 PM
1500 starts instantly upon release of start button Gayle Goldwing Technical Forum 8 12-07-2005 10:25 PM
