Fuel & Temp Guages and reverse do not work - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 05-01-2016, 07:43 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Send a message via Skype™ to john.amato1
Unhappy Fuel & Temp Guages and reverse do not work
Good afternoon,
I am frustrated. Last week my Honda Goldwing was working and yesterday, the fuel and temperature gauges do not work. I also noticed that when I am riding the shift to 5th gear, the light does not come on. When I put my bike in reverse, the bike does not move.
Could it be one of those relays, say # 3 or # 6?
Can anyone help.
Thanks
john
john.amato1 is offline
post #2 of 11 (permalink) Old 05-01-2016, 08:12 PM
Year: 94
Model: 1500 SE
I recall reading this symptom set before. You are on the right track with the relays, and ck the Reverse switch
beyond that -until the electrical gurus get home from riding, begin a search on here with same words used in this thread title, or scroll thru the technical section and you will find something last posted within 1 or 2 months = that will have your cure!
Thats the great thing about this forum, chances are someone has encountered the same prob and fix~
Aloha Tom is offline
post #3 of 11 (permalink) Old 05-01-2016, 09:10 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
The items not working are powered from the Tail Main Relay # 3.
But check the # 8 tail illumination (15-amp) fuse first.
It will not be the reverse lever switch.
DBohrer is online now
post #4 of 11 (permalink) Old 05-01-2016, 11:18 PM
Welcome to the forum, John.
I suspect DBohrer has this under control.
post #5 of 11 (permalink) Old 05-01-2016, 11:30 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Swap the top right hand relay in the relay box with another relay in that box of the same amperage. See if that works better.
gumbyred
gumbyred is offline
post #6 of 11 (permalink) Old 05-02-2016, 08:21 AM
Bellboy40's Avatar
Year: 2000 & 1994
If you will do what DBohrer says you will find the problem. He knows his stuff on electrical.
Larry
-- Albert Einstein
Bellboy40 is offline
post #7 of 11 (permalink) Old 05-02-2016, 10:00 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Thanks, I will check the reverse too
post #8 of 11 (permalink) Old 05-02-2016, 10:01 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Thanks
post #9 of 11 (permalink) Old 05-02-2016, 10:03 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Thanks, I will try that
post #10 of 11 (permalink) Old 05-02-2016, 10:05 PM Thread Starter
Year: 1994
Model: GL 1500 SE
Thanks. I have the same Goldwing color as yours. What a beauty.
GL 1500: rear lights, fuel gauge, temperature gauge, reverse.... have ceased to work AlpineGoldwing Goldwing Technical Forum 5 07-15-2015 05:18 PM
Carb synch, Vacuum Guages or Mercury Guages - which are best? goldie4ever Goldwing Technical Forum 15 04-04-2010 11:05 AM
No reverse, no reverse lamp and no water temp & gas gauges! Clarkins Goldwing Technical Forum 8 08-03-2007 09:09 PM
Gas, Temp gauges, Reverse all stopped working The Balloon Guy Goldwing Technical Forum 17 05-23-2006 11:59 AM
82 Interstate fuel and temp guages. medicj Goldwing Technical Forum 5 11-03-2005 02:47 PM
