Clutch issues - Page 2 - Steve Saunders Goldwing Forums
 7Likes
post #11 of 15 (permalink) Old 05-07-2016, 01:09 AM
rgmr250's Avatar
Model: 97 gl1500 SE
Why not check the clutch bushing as the push rod could be working it's way out the lever.
http://goldwingdocs.com/forum/viewtopic.php?t=12622
Yes, a good point, I was fixing up an old 80's Honda Shadow earlier this year that had this problem. Luckily I keep a spare bushing 'in stock' in my garage.
Current rides:
2010 Husqvarna TE250
2015 Kawasaki Ninja 650
2008 GL1800 with bagger kit
1997 GL1500SE
rgmr250 is offline
post #12 of 15 (permalink) Old 05-07-2016, 09:18 AM Thread Starter
Year: 1985
Model: GL1200
Thanks everyone! I'll check the M/C, and hopefully I can get to it this weekend... Thanks again for the help!
redrover94 is offline
post #13 of 15 (permalink) Old 05-08-2016, 12:17 AM
Year: 94
Model: 1500 SE
this is in reply to multi quoting on page 1 by spiralout
I write things thinking ahead- geared towards other relatively noobs/new to Wing who will find these threads while researching their own problem in the future. Gurus and skilled persons may skip the basic info that they should already know~
Are we not here to help each other- learn from each other?
The Dot3/4 info is because I have seen that very question posed several ways- and Im also on a mission to get everyone on a brake fluid flush
At least every 2 years, every year is better! Do the clutch while you are at it.
Hence suggestion to ck brake master rubber condition ( it may be gone or damaged) and flush the system while you are there.
NOTE Once you open the foil seal on brake fluid bottle- it goes bad after 6 months on the shelf from the dreaded hygroscopic action...
So use up the contents of the bottle by doing all your vehicles! c'mon you're already dirty
The missing rubber = my 86 Shadow clutch res -the fluid hadnt been changed in a decade or more, and the rubber was stretched, sunken and discolored!
No surprise the slave cyl was destroyed from scarring and pitting in the bore.
That is when I learned about burping the banjo
The brake master needed a new one as well- good thing I ckd!
I hope this clears up any confusion for spiralout- and allows everyone to enjoy my post for the info/entertainment they are meant to be.
Im trying- IMO that beats a lot of post that just pick on other post~
Please Be kind- this IS my social life!
Aloha Tom is offline
post #14 of 15 (permalink) Old 05-08-2016, 12:35 AM
Tom, you do have a lot of knowledge to share here however most of it is hidden in your verbal diarrhea.
If you have an answer to a question post it but don't go on and on and on off topic.
Ken Bergen is offline
post #15 of 15 (permalink) Old 05-25-2016, 09:32 PM
Mr Magic Fingers's Avatar
How did you make out with this issue? Have you resolved it?
Inquiring minds want to know!
Tim
____
Please visit
Mr Magic Fingers is offline
'84 Clutch Issues. Bike...and Dennis Goldwing Technical Forum 8 10-03-2014 11:02 PM
HD Clutch issues... UbarW General Motorcycle Discussion Forum 4 10-17-2013 07:51 PM
Clutch Issues ELK New Members Introduction Forum 15 05-25-2012 01:20 AM
clutch issues want to ride Goldwing Technical Forum 19 06-25-2011 10:05 AM
Clutch Issues? 4evermetric Goldwing Technical Forum 22 01-31-2010 02:55 PM
