Cruise control fix if Cruise on Light bulb burned out - Page 2 - Steve Saunders Goldwing Forums
 2Likes
post #11 of 16 (permalink) Old 05-08-2016, 12:00 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Originally Posted by rgmr250 View Post
I used regular white LED's - the dash warning lights are brighter now - I can see them easily in the sun, but are maybe a touch bright at night. The backlighting is better, but a little overpowering on the top section of the gauges, but works better for me than the dim lighting that was there.
Keep in mind that, if you have hot spots on the gauges, that is because of the type of the LEDs. There are LEDs which have concave lens reflecting the light to the sides rather than front.
Erdeniz Umman is online now
post #12 of 16 (permalink) Old 05-08-2016, 01:09 AM Thread Starter
rgmr250's Avatar
Model: 97 gl1500 SE
The ones I used look like this: http://www.carpartslights.com/images/t10-5%20smd.jpg
Because they have 5 LED's, they should distribute light fairly similarly to a regular bulb. I think they're just a lot brighter and therefore create the hotspots. Attached is a pic (garage lights off, no flash, dash lights on). You can see the hot spots at the top left and top right. I'm quite ok with it, particularly since 0-140KM/h is well lit (I'm not generally riding past 140...) and the tach is lit in the important ranges as well...
Before the LED's, the 160-220 range on the speedo was about the brightness of the entire speedo and tach.
The camera really doesn't pick up the LCD - it's much, much more readable than the picture show.
Current rides:
2010 Husqvarna TE250
2015 Kawasaki Ninja 650
2008 GL1800 with bagger kit
1997 GL1500SE
rgmr250 is offline
post #13 of 16 (permalink) Old 05-08-2016, 01:39 AM
Yesterday, I bought those for the front position lights next to the headlight. They are too bright to be used in dash panel, I think.
Haven't you replaced the ones for the LCDs?
post #14 of 16 (permalink) Old 05-08-2016, 01:35 PM Thread Starter
rgmr250's Avatar
Model: 97 gl1500 SE
I replaced the top one in the LCD (same bulbs as the others). Oddly, to the human eye, it's much brighter, but the camera just doesn't pick it up. I didn't replace the bottom bulb, since you have to take the IP partially apart, I think, to get to it. Next time I'm in there, I'll probably replace the bottom backlight bulb in the LCD.
Current rides:
1997 GL1500SE
rgmr250 is offline
post #15 of 16 (permalink) Old 05-08-2016, 01:38 PM
Originally Posted by joe in calif View Post
On the 1800 wing you can dim the dash lights for day riding and that will help the life of the bulbs but on the 1500 there is no adjustment but they are dull anyway.
Don't know what year bike you got, but on my '02 the dimmer only controls the lights for the left hand handlebar controls.
post #16 of 16 (permalink) Old 05-08-2016, 02:51 PM
It is quite easy, you will have to remove speedometer and then LCD screen. If I am not mistaken it was a smaller size bulb.
GL1500 Cruise Control lag fix rcurtisjr Goldwing Technical Forum 10 08-23-2013 10:26 PM
GL1500 cruise contol light bulb assembly fast freddy Goldwing Technical Forum 5 01-24-2012 06:16 PM
GL1500 cruise control light Bigwavedave Goldwing Technical Forum 3 07-29-2011 11:28 AM
1500 cruise control fix Danimal Goldwing Technical Forum 10 08-07-2010 01:14 PM
cruise control unit led won't light. :( johnfly Goldwing Technical Forum 9 05-04-2007 05:43 PM
