Possibly stripped oil drain bolt? - Page 2 - Steve Saunders Goldwing Forums
post #11 of 16 (permalink) Old 05-09-2016, 11:55 PM
http://www.ebay.com/sch/i.html?_from...COVER&_sacat=0
Looks like it may be cheaper to just get another cover.
I've bought a 14mm thread insert kit for less than the EvilBay sellers want for the cover.
It came with six inserts and I didn't need a gasket kit.
Ken Bergen is online now
post #12 of 16 (permalink) Old 05-10-2016, 01:20 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I don't know what the thread pitch is on that bolt but I think a kit like this is what your talking about Ken.
looks like you use the over size tap then install the insert.
Do you think this kit would work for the OP?
http://www.ebay.com/itm/14mm-Spark-Plug-Re-thread-rethread-rethreader-repair-Tap-tool-Reamer-Inserts-Kit-/201164211368?hash=item2ed65244a8:g14AAOSwnDZUCoF 6&item=201164211368&vxp=mtr
JeffMayfield is offline
post #13 of 16 (permalink) Old 05-10-2016, 01:50 AM
We used to call them helicoils. But that was back in the old days.
post #14 of 16 (permalink) Old 05-10-2016, 03:33 AM
Helicoil is a brand name and back in the old days the knockoffs didn't hit the market before the original brand.
post #15 of 16 (permalink) Old 05-10-2016, 06:07 AM
Helicoil is a different thing, they are not a solid insert but a coil like a slinky. They work well, I have used a lot of them.
post #16 of 16 (permalink) Old 05-10-2016, 06:58 AM
Mr Magic Fingers's Avatar
Hey guys,
There is still one more way to fix this and overcome a problem on the GL1100 at the same time. I had to do this to my 82 Aspy for this very reason.
I just installed a 3rd party dipstick!
You will have to look around to find one but I am sure there are ones out there or you could possibly even make one if you are handy. They are not rocket science.
I knew my threads were in hard shape so I picked up a new dipstick "kit", installed the adapter into the transmission case with some red or blue lock tight and let it set. It never has to come out again anyway.
From this point all you have to do to drain the bike of oil is to take off the tube with the compression fitting. You have the MUCH added benefit of NEVER having to get on your hands and knees to look at that damn sight glass again!!!!! What the H**L was Honda thinking. Now it's easy to check your oil and no excuses.
There are a few posts on here about dipsticks if you search.
Tim
File Type: jpg Fluid Drain Plugs 2 - 82 Aspencade.jpg (212.4 KB, 17 views)
____
Please visit
Mr Magic Fingers is offline
stripped threads out of fork oil drain hole, doh! Msteele Goldwing Technical Forum 20 04-09-2013 02:46 AM
Stripped GL1100 oil drain plug rex Goldwing Technical Forum 16 03-25-2011 08:03 PM
Oil Drain Stripped - Heli-Coilled, but still have leak wagoss Goldwing Technical Forum 3 06-22-2009 12:45 AM
Oil filter bolt stripped tybme Goldwing Technical Forum 17 08-08-2007 07:51 PM
oil drain plug stripped junemann Goldwing Technical Forum 12 08-02-2007 11:30 AM
