Possibly stripped oil drain bolt? - Steve Saunders Goldwing Forums
post #1 of 16 (permalink) Old 05-08-2016, 05:54 PM Thread Starter
Question Possibly stripped oil drain bolt?
I have an '83 GL1100, changed the oil, tightened the drain plug back in to the specified 28 fl.lbs, and it would never get that tight - the bolt just spins and spins. Is there some kind of mechanism, like a 2-part assembly, to prevent the bolt from over-torqueing, or did i actually just strip the bolt? I'm afraid to take it out to look at it, because I started the bike, took it for a short ride, and it's not leaking any oil.
mattcorby is offline
post #2 of 16 (permalink) Old 05-08-2016, 06:00 PM
Obviously stripped. A new drain plug crush washer would have prevented that. A thread insert is the best fix.
post #3 of 16 (permalink) Old 05-09-2016, 01:40 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Just a thought, you may try a longer bolt which maybe can catch a few threads.
Bike...and Dennis likes this.
Erdeniz Umman is offline
post #4 of 16 (permalink) Old 05-09-2016, 09:33 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
That's what happened to me. An after market magnetic bolt peeled a thread while removing and even a new oem bolt wouldn't tighten up. Got a longer bolt with same thread pitch from a wreckers, (I think it came out of a Suzuki) and that did the trick.
PS: I never use a torque wrench on it, just snug then a short bump on the wrench.
busdriver is offline
post #5 of 16 (permalink) Old 05-09-2016, 09:48 PM
Once you've stripped out most of the threads don't expect a longer bolt to hold long on the one or two threads left.
There are only two fixes I would trust.
1: As Dave said, a thread insert.
2: A new to you transmission cover with good threads.
Ken Bergen is online now
post #6 of 16 (permalink) Old 05-09-2016, 09:56 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Is it even possible to drill for an insert with the engine in the frame?
JeffMayfield is offline
post #7 of 16 (permalink) Old 05-09-2016, 10:13 PM
It's a GL1100 with the drain bolt in the front transmission cover so yes.
post #8 of 16 (permalink) Old 05-09-2016, 10:17 PM
Busdriver
busdriver's Avatar
Year: 1990
post #9 of 16 (permalink) Old 05-09-2016, 11:12 PM
IRAQI RAM's Avatar
Year: 1997 SE
Find someone with a time-sert
IRAQI RAM is offline
post #10 of 16 (permalink) Old 05-09-2016, 11:45 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
http://www.ebay.com/sch/i.html?_from...COVER&_sacat=0
Looks like it may be cheaper to just get another cover.
stripped threads out of fork oil drain hole, doh! Msteele Goldwing Technical Forum 20 04-09-2013 02:46 AM
Stripped GL1100 oil drain plug rex Goldwing Technical Forum 16 03-25-2011 08:03 PM
Oil Drain Stripped - Heli-Coilled, but still have leak wagoss Goldwing Technical Forum 3 06-22-2009 12:45 AM
Oil filter bolt stripped tybme Goldwing Technical Forum 17 08-08-2007 07:51 PM
oil drain plug stripped junemann Goldwing Technical Forum 12 08-02-2007 11:30 AM
