1500 Compression - Steve Saunders Goldwing Forums
  • 1 Post By redwing52
post #1 of 6 (permalink) Old 05-18-2016, 05:38 PM Thread Starter
Model: 1999 goldwing se
1500 Compression
Since I have the carbs. off, I decided to do a compression test on the engine to see how good it is on a 20,000 mile goldwing trike. The good news is that all 6 cylinders were within 2 to 3 pounds of each other. The bad news( I hope I'm wrong) is that all were reading 100 lbs. Isn't that awful low? I thought they would be up around 200 lbs. This was with like I said the carbs. off so the throttles were wide open and the battery was fully charged and all plugs out. So why is it so low? Hopefully you will make me feel good and tell me everything is OK. Thanks
RKB53 is offline
post #2 of 6 (permalink) Old 05-18-2016, 05:40 PM
Engine was cold...
redwing52 is offline
post #3 of 6 (permalink) Old 05-18-2016, 05:54 PM Thread Starter
Unfortunately the answer is yes and I know that it should be warmed up, but still isn't 100 lbs. low even for a cold engine?
RKB53 is offline
post #4 of 6 (permalink) Old 05-18-2016, 09:27 PM
Nope, and it might not even be as much that it is cold but no oil on the cylinders add to it. I think not to worry.
StevetotheH likes this.
post #5 of 6 (permalink) Old 05-19-2016, 01:02 AM
StevetotheH's Avatar
Year: 1984
Make: Aspencade
Model: GL1200 SE
The only thing to worry about on a cold compression test is a single cylinder that comes to life when warm, or only when oil soaked. 100+ on all should result in some pretty good numbers warm. I've hit lower numbers on cold small blocks. Also, I hope that wasn't with a Harbor Freight rig. Pretty much destroy 50% of those taking them out of the plastic case.
StevetotheH is offline
post #6 of 6 (permalink) Old 05-19-2016, 05:30 AM Thread Starter
OK thanks for the info. and the calming feeling that I now have. As long as 100 lbs. is fine on a cold engine, I can move on to my next problem. Stay tuned, and thanks again. Randy
RKB53 is offline
1500 goldwing no compression goldbike Goldwing Technical Forum 15 06-10-2013 08:55 AM
Compression newtothisgold Goldwing Technical Forum 16 10-10-2010 03:07 PM
gl 1500 valve compression tool rstar96 Goldwing Technical Forum 7 11-21-2009 10:34 AM
Compression? Night_Train01 Goldwing Technical Forum 12 08-28-2008 08:09 AM
compression? big daddy Goldwing Technical Forum 11 05-18-2006 11:49 AM
