1500 hazard lights - Steve Saunders Goldwing Forums
  • 1 Post By Bellboy40
post #1 of 10 (permalink) Old 06-09-2016, 07:20 PM Thread Starter
Make: Goldwing Aspencade
1500 hazard lights
My hazard lights only work when I have a turn signal on and then it is only for about 10 seconds. Any ideas on the fix?
Ed
near Philadelphia
fordf3truck is offline
post #2 of 10 (permalink) Old 06-09-2016, 08:54 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Hazard Lights
Here is the voltage flow:
1. Ignition switch sends voltage to the "acc" 10-amp fuse. (Light green/black wire)
2. Acc 10-amp fuse sends voltage to the Hazard relay. (Light green/black wire)
3. Hazard relay sends voltage to the Hazard switch. (Pink/white wire)
4. Hazard switch sends voltage to the left and right turn signal bulbs.
a. Light Blue wire to the right bulbs.
b. Orange wire to the left bulbs.
1. Check the fuse.
2. Check the relay.
Note: You can check for output from the relay at the 22-pin White connector under the seat. (Pink/White wire) Might be in a black plastic case....!
DBohrer is offline
post #3 of 10 (permalink) Old 06-09-2016, 09:08 PM
Might just be a dirty switch. Open up the pod and spray it down a few times with WD-40 while cycling the button a few hundred times.
post #4 of 10 (permalink) Old 06-09-2016, 09:32 PM
I doubt that water is the problem but I've been wrong before.
Ken Bergen is offline
post #5 of 10 (permalink) Old 06-09-2016, 10:33 PM
Ken, you know WD-40 also cleans and lubes.
The reason I suggested this was because when my switches start acting erratically, it's usually been just an accumulation of various tiny bits of communist propaganda sent over here on the prevailing westerlies to infiltrate our motorcycles and cause them to act like Urals.
So I use War-game Defence-40, to protect my ride.
post #6 of 10 (permalink) Old 06-09-2016, 10:45 PM
This advertisement is brought to you by the CEO of the Water Displacement formula 40 fan club.
post #7 of 10 (permalink) Old 06-10-2016, 04:46 PM Thread Starter
Thanks for the help, here is the whole story.
My throttle cable broke a couple of weeks ago and I replaced it (A cable). Since then I needed my hazard lights and have the aforementioned problem with them.
I also realized my cruise control will not set.
Can you give me more info on how to check the wire in the 22 pin connection to see if the hazard relay is working?
Thanks again
Ed
near Philadelphia
post #8 of 10 (permalink) Old 06-10-2016, 05:17 PM
Year: 94
Model: 1500 SE
How is the operation of the hazard switch? it moves freely in and locks in ON position and releases freely to stop the hazards??
My 94 would not turn them ON one day when needed, the next morning I started the bike and hazards would not turn off!
Used CRC electrical contact spray cleaner and lot of pushes of said switch till it freed up-- and suddenly a red stripe appeared, then a red block,,the top of the button now extended for OFF
Plan to go inside switch housing with cleaner and a tube of dielectric grease to fix right.
Thats the problem with cleaners, you wash away the dried up lubricant!
So to keep it from working smoothly in the future = you need to replace that stuff.
Aloha Tom is offline
post #9 of 10 (permalink) Old 06-10-2016, 05:19 PM
Year: 94
Model: 1500 SE
with throttle cable job- there is a switch that disconnects the cruise when you roll off throttle slightly.
Is that all hooked up correct?
post #10 of 10 (permalink) Old 06-10-2016, 07:25 PM
Bellboy40's Avatar
Year: 2000 & 1994
Originally Posted by fordf3truck View Post
snip...
Thanks again
Ed
near Philadelphia
The connector is under the seat toward the rear on the left side. It is a white 22 pin connector on the Aspencade. You can put your voltmeter or test light between the pink/white wire and the other lead to ground. You should see battery voltage there with the ignition switch turned on. As DBohrer said, the connector may be inside a plastic case that you can pull apart to get to it. If you can't get your meter lead on the wire with the connector still plugged in, you can take it apart and measure the voltage on the side coming from the rear.
DBohrer likes this.
Larry
-- Albert Einstein
Bellboy40 is offline
Hazard lights GL1500 Doxbike Goldwing Technical Forum 3 06-29-2011 08:42 AM
hazard lights Dragoon General Motorcycle Discussion Forum 7 10-29-2008 10:09 PM
hazard lights DoDefoort Goldwing Technical Forum 2 04-04-2008 01:00 PM
Hazard Lights buckodub Goldwing Technical Forum 13 03-19-2008 09:57 AM
83 gl1100 hazard lights hector Goldwing Technical Forum 5 05-07-2006 11:47 AM
