1500se staunchings - Steve Saunders Goldwing Forums
 9Likes
post #1 of 12 (permalink) Old 06-12-2016, 01:45 PM Thread Starter
Model: 1500 se
Smile 1500se staunchings
Hi every one can some one plz help me on a technical prob stripped forks down on my 1500 se British model as the staunchings need re chromeing bagged and tagged all bits left hand right hand but I am going to relace all bushes and seals and fit progressive springs anyway but on inspection of staunchings noticed inside on leg there is a plastic washer / ferrel at bottom near damper rod being the numpty that I am I mixed up the staunchings so I need to know
1 what side does this go on I think it's left
2 will it need to be removed for chromeing and if yes how
There is no info in manual so I am at a loss at moment thanks for your help
Gigg000 is offline
post #2 of 12 (permalink) Old 06-13-2016, 12:09 AM
First, welcome to the forum.
As to your question...
...mostly I'm not sure with all you are saying, but, if you are asking about the fork legs, I'd think the brake mounts should make it obvious which is left, or right.
post #3 of 12 (permalink) Old 06-13-2016, 12:20 AM
Cornpone's Avatar
Lost in translation....
sidvicious likes this.
Cornpone is offline
post #4 of 12 (permalink) Old 06-13-2016, 04:10 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
Oh, a looooong sentence without any punctuation.
Erdeniz Umman is offline
post #5 of 12 (permalink) Old 06-13-2016, 05:58 AM
Would you please ask your question according to the names of the parts given in the picture below?
post #6 of 12 (permalink) Old 06-13-2016, 06:12 AM
As he's re-chroming the staunchings I would think fork tubes.
That's about all I understood.
Ken Bergen is offline
post #7 of 12 (permalink) Old 06-13-2016, 10:32 AM
Year: 94
Model: 1500 SE
Yes he means fork tubes or stanchions. The question posed: Inside at least one of the forks was a washer or nut
He wants to know which fork this goes in, can it be removed now, and is it needed with upgrade to Progressive brand springs
Seems like I read something about a spacer-washer in Clymer repair book?
Doesnt it get tossed out when doing the upgrade springs??
Note for OP: Buy 1 QT bottle of 15-weight fork oil- your choice of brand, Each fork tube needs approx 11 oz with Prog springs-
They displace more fluid, so you use less fluid than is called for stock.
Also for OP and gurus- isnt just the top slider section of the forks chromed?
with the outer or lower half of fork leg having a plain finish inside- not chrome?
Which means only the top part of the forks goes to the plating shop
Or am I wrong again?
Gigg: did each fork contain 2 springs with a washer between them.,is that what you found- a loose washer now?
OR you see something in bottom of lower section - stuck like its welded on?
Aloha Tom is offline
post #8 of 12 (permalink) Old 06-13-2016, 10:46 AM
IRAQI RAM's Avatar
Year: 1997 SE
He lost me after hi. Mentioning bagged and tagged didn't help either, I thought of the Sherriff of Nottingham upset at Robin Hood for getting a buck or stag or whatever the forest rats are called over there. Numpty had me google translating the meaning.
Seriously, the issue is the fork tubes and a washer. It is not needed with progressive springs, I am not certain of the pastic washer that you mentioned though. Best of luck to you.
IRAQI RAM is offline
post #9 of 12 (permalink) Old 06-13-2016, 11:43 AM
Dannyboy1949's Avatar
Model: 1998 SE SOLD But Not Forgotten!
Seems like some of you who replied are being willfully dense. The original post is not at all hard to understand and chiming in with useless comments is a poor way to welcome a forum user.
Kudos to Aloha Tom for actually trying to help this gentleman!
Aloha Tom likes this.
Dan & Jo Ann
The journey IS the destination .
Dannyboy1949 is offline
post #10 of 12 (permalink) Old 06-13-2016, 05:48 PM
Year: 94
Model: 1500 SE
bagged and tagged is clearly a statement that when removing the small parts he placed them in separate ziplocks-
with a tag indicating which fork leg they came from!
Now he has a part he cant identify, and which fork it goes to, we need a pic Gigg please!
1500SE TKM Goldwing Technical Forum 3 06-24-2011 03:19 PM
1500se Calvin Davidson New Members Introduction Forum 15 04-30-2011 04:10 PM
97 1500se ThunderBats Goldwing Technical Forum 10 10-24-2010 01:33 PM
No FM on 1500SE racertim Goldwing Technical Forum 12 03-16-2010 11:52 AM
98 gl 1500se xsxlr8r Goldwing Technical Forum 4 07-17-2009 01:27 PM
