Curious re. the early FI Wings. - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 06-12-2016, 08:21 PM Thread Starter
Year: '98 Valkyrie Tourer, '84 Std. restoration in process
Model: GL1200
How reliable is the FI system on those bikes? I've heard pros and cons re. that but it seems to me the owners of such models are quite satisfied with them. Any good opinions based on personal experience?
TIA
John Schmidt is offline
post #2 of 9 (permalink) Old 06-12-2016, 10:14 PM
I had an '86SEi and it was flawless, it now resides in the garage of OnaWingAndaPrayer down in San Antonio, FL
it had a few minor computer issues, but it always started and it always ran smooth as clockwork.
post #3 of 9 (permalink) Old 06-12-2016, 10:43 PM
Magic Moderator
trike lady's Avatar
I had a friend who had an 86 SEi, the only problem he had with it was the stator went south other than that the bike ran great.
Retired trike builder.
trike lady is offline
post #4 of 9 (permalink) Old 06-12-2016, 11:58 PM
The real problem with those models is, if something does go wrong, many parts simply are not available. New or used.
post #5 of 9 (permalink) Old 06-13-2016, 08:07 AM
Bellboy40's Avatar
Year: 2000 & 1994
I bought a 85 LTD new and kept it for 24 years. It always ran flawlessly and had zero problems with the fuel injection system. Wish they had put the injection on the 1500s.
Larry
-- Albert Einstein
Bellboy40 is offline
post #6 of 9 (permalink) Old 06-13-2016, 05:42 PM Thread Starter
Model: GL1200
Yes, I know Mike, we swap emails from time to time. I'm looking at an FI engine that seems like a good deal. Since my Std. is carbed, Mike said he wants the FI stuff for spares but.....I got to thinking. Since the engine is complete with everything including the wiring necessary, why not just install the entire thing as is. Sure would save me some time making the changeover and pulling all the new parts I've installed on the present motor.
I'm getting a bit of static from the "front office" re. spending the money so will have to wait and see if I can pull it off.
post #7 of 9 (permalink) Old 06-13-2016, 05:53 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
not saying it cant be done but making an 84 FI,would probably be easier just buying one,
the frame would probably be the only small thing that would be usable
neoracer is offline
post #8 of 9 (permalink) Old 06-14-2016, 03:06 PM Thread Starter
Model: GL1200
This setup has everything except the FI tank, the fuel pump and its associated plumbing so I could convert it fairly easy. I bought it this morning, should be here by week's end. Since I already have gone through the carbs and a friend down here wants the FI stuff for spares, I'll just swap out everything and make a carb engine out of it. My present skeeter killer(not valve seals) has new belts, water pump, clutch servo, a number of other things which I'll pull and reinstall.
I actually talked to the guy that checked out the bike before breaking it down. I can only hope his words of "it's a sweet running motor" are true, said compression is in the 160's across the board.
post #9 of 9 (permalink) Old 06-15-2016, 03:57 PM
Model: 1986 SE-i
My SE-i has been running well for the 12 years that I've owned it. Had to replace the stator and regulator. The only problem I've had with the FI system was fixed by replacing the 25 year old vacuum lines a few years back. Starts right up every time and surprises some other riders when I get the revs up. I have collected most of the spare parts that I need just in case, though. I was even able to buy one of the last new crank sensors sold. I keep that in a secret place under lock and key.
I'd recommend owning one. But only if you can do the work yourself if you have issues. It took me a while to learn how it works thanks to the people on this board. I wouldn't want a local mechanic learning on my time!
'86 SE-i
There is no problem in life that a sufficient quantity of high explosives won't solve.
wildman is offline
good website for early wings peterbilt Goldwing Technical Forum 1 08-07-2010 11:38 PM
early wings handleling question...help denny b General Motorcycle Discussion Forum 11 09-18-2009 10:30 PM
Mismatched carbs on early wings, how do they run? Texwing Goldwing Technical Forum 3 04-17-2006 10:15 AM
Stripped carb bowl screws on early wings agingwarrior Goldwing Technical Forum 6 03-23-2006 11:26 AM
Lower handlebars for early 'wings sanfelice Goldwing Technical Forum 1 02-16-2005 10:26 PM
