84 interstate sputtering at low speed - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 06-17-2016, 08:25 PM Thread Starter
Model: 84 interstate
Smile 84 interstate sputtering at low speed
Bike is running quite well all things considered, starts fairly easy in morning,I let it warm up, I go down my driveway make complete stop at bottom, then take off all is good, I drive in to town about 7 miles, come to first stop sign. As soon as I leave the stop sign it sputters until i get going a little bit faster or gun it just a bit.
No danger of stalling at all just sputtering,I have had this about 3 weeks now, have ran 2 cans of seafoam through it, I actually used a entire bottle with full tank and done that twice. I then tried a tank of high test
I dont know, I think its a little better or I am just getting used to it, like I said first thing in the morning after being warmed up I pull out of the driveway from a stop with no sputering, it only starts when I hit the first stop sign and then go again
I am getting pretty good at dealing with it, I find if I just so very slightly delicately turn the throttle I can fake it a bit.. its also a bit embarrassing sputtering(pride goeth before the fall) through town at 40 Khm through town street.
I know everybodys going to say clean your carbs, people always say that, it may be the case but ?
I put on a new fuel filter, looked for leaks in vaccuum hoses and gas lines. I put brand new spark plugs in last year, its running on all 4 down the hyw fine, maybe its not fuel?
Any suggestions?
If I thought new plugs would do the trick I would certainly do it, just that last year the plugs were so hard to remove...yep I greased the thread before putting back in , 3 of them went back in easy one went back in tight, not stripped just tight, but am leary of pulling them unnecessarily, I made a note of the hard one, but could replace the other 3 if that would help, but I dont think thats the problem
Slim Pickens is offline
post #2 of 14 (permalink) Old 06-17-2016, 08:38 PM
When it doesn't sputter do you still have the choke on a bit?
Ken Bergen is online now
post #3 of 14 (permalink) Old 06-17-2016, 08:41 PM
Magic Moderator
trike lady's Avatar
Have you done a carb sync?
Original dog bone fuse? If it is an interruption of electrical power to the ignition system.
That's what comes to mind so far for me.
Retired trike builder.
trike lady is offline
post #4 of 14 (permalink) Old 06-17-2016, 09:40 PM Thread Starter
No choke at all Ken after starting
post #5 of 14 (permalink) Old 06-17-2016, 09:41 PM Thread Starter
Thanks Trike Lady I have a standard fuse now, No have not synced carbs, never had...I will look up and see if its something I can do, I believe it requires a tool doesnt it
I took the carbs off pretty well once to put choke cable on a few years ago, So maybe cleaning carbs is not so difficult
will look up Sync carbs, I have a manual, I was trying to avoid cleaning carbs, no sybcing is different, just talking out loud
post #6 of 14 (permalink) Old 06-17-2016, 10:03 PM
Cornpone's Avatar
On a running Wing Seafoam should clean the carbs fine. +1 on carb synch; it requires a vacuum gauge, but you probably know someone who has one, and their not expensive. Also, I set my idle to 1,000rpms, not the 900 recommended, for smoother take offs.
Cornpone is offline
post #7 of 14 (permalink) Old 06-17-2016, 10:08 PM Thread Starter
looking at this Steve saunders video on youtube, I can do thi
post #8 of 14 (permalink) Old 06-17-2016, 10:09 PM
Year: 1985
Model: 1985 Gl1200A
I have an 85 Aspencade that sputtered / stumbled.
I got rid of it by:
1) Shimming the needles
2) Adjusting the mixture screws
3) Syncing the carbs
AZgl1800 likes this.
froche is offline
post #9 of 14 (permalink) Old 06-18-2016, 07:39 AM
Bellboy40's Avatar
Year: 2000 & 1994
Your statement about it sputtering at about 40 km per hour down the street made me think about how my former 81 interstate used to sound when riding easily through town. It had sort of a stuttering sound but with just the least amount of throttle it would smooth out. I took the slides out of the carbs and polished the bores and the slides and that helped a lot. Also would put a couple ounces of MMO in the fuel about every other tank and that helped keep it from doing it. That MMO helped with keeping the slides lubed so they didn't stick in the bore. At least that is my theory and I'm sticking to it!
Larry
-- Albert Einstein
Bellboy40 is online now
post #10 of 14 (permalink) Old 06-18-2016, 09:13 AM Thread Starter
Thanks to everybody, going to try everything mentioned...btw while thanking everybody some stuff looks like it disappeared, at least from my end
GL1500 sputtering at high speeds when fuel gets low..... pwhoever Goldwing Technical Forum 15 08-15-2012 03:09 AM
Sputtering at low RPMs! GL1500 Starfire Goldwing Technical Forum 2 07-06-2012 05:57 PM
Sputtering at low RPM. Fuel problem of some sort? smocksam Goldwing Technical Forum 4 09-10-2010 09:11 PM
Need driving lights for low beam/low speed gido Goldwing Technical Forum 6 10-01-2008 03:29 PM
Low speed miss 86 interstate lynsox Goldwing Technical Forum 2 08-31-2007 10:53 PM
