Clutch Job - Steve Saunders Goldwing Forums
 4Likes
post #1 of 21 (permalink) Old 06-30-2016, 02:26 AM Thread Starter
L8ndeb's Avatar
Year: 1995
Model: Interstate
Send a message via Yahoo to L8ndeb
Clutch Job
Hello All,
I'm afraid it's about time to put in a new clutch on my '95 Interstate. I would like to have the parts on hand when I do the job. My question is, what would be the parts list for a normal/average clutch job?
TIA
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #2 of 21 (permalink) Old 06-30-2016, 04:05 AM
Mr Magic Fingers's Avatar
Hello there L8ndeb,
Why do you feel that your clutch needs to be replaced? What are the symptoms that you are having?
The clutches on these bikes are pretty awesome and tend to have a great life expectancy. What s the mileage?
Tim
redwing52 likes this.
____
Please visit
Mr Magic Fingers is offline
post #3 of 21 (permalink) Old 06-30-2016, 10:42 AM
Yeah, what Tim said.
post #4 of 21 (permalink) Old 06-30-2016, 04:20 PM
Year: 94
Model: 1500 SE
Is the clutch slipping like a car does with bad clutch ie: hard throttle uphill and it revs up without forward propulsion?
OR clutch lever doesnt engage until nearly touching the grip on handlebar?
Does it act like a clutch slave leak, losing fluid from master cyl and a few pumps of lever improves it temporarily?
Thats more common failure (easy rebuild) than friction plate wearout
UNLESS
Its been pulling a trailer 2 up thru the mountains and has more than 120-150kmiles
THEN I would easily believe friction wearout
It can also be internally bypassing, meaning the fluid will remain at full = but seal in master cyl doesnt build any pressure.
CK honda and EBC for kits, they sell the friction plates separate from the steel plates that go between them, if its not slipping bad the steel is probably good = not burnt.
Im sure many will say Honda only--as if we knew who actually makes Hondas clutch parts. I prefer EBC = well known for their friction products
I dont know Wing clutch parts prices, but my 86 Shadow which shares many of the same parts were well under $100 for the friction plates
Thats all I replaced and it went back to hooking up in response to throttle application
Dont forget new engine/trans oil to rid the system of any loose particulate matter.
The new clutch plates shed material slightly too, so keep an eye out for early oil change needs -- the first time
Aloha Tom is offline
post #5 of 21 (permalink) Old 06-30-2016, 11:03 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
What type of oil are you using? Put any type of additive in the oil? Outside of a few ounces of Seafoam 100 miles or so before oil change? Clutch fluid been changed, and bled recently? If this is not done at least every other year it might need clutch master cylinder rebuild, and slave cylinder also. Like mentioned earlier these are stout clutches. My 1500 just turned 203K, and clutch still locks up strong. And I pull a heavy trailer quite a bit. Change and bleed clutch fluid every year.
gumbyred
gumbyred is offline
post #6 of 21 (permalink) Old 07-01-2016, 04:19 PM Thread Starter
L8ndeb's Avatar
Year: 1995
Model: Interstate
Hi Guys and thanks for the replies. The symptoms are the clutch not engaging until it is close to the handlebar. The clutch fluid is starting to lower in the reservoir. I use Chevron Delo only, no additives. The previous owners had a camping tent trailer and used it often, lived in Denver. It has 80K on the meter. I have not changed and bled the clutch fluid. There are NO leaks. (I hate leaks!)
Any other comments with this additional information welcome.
TIA
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #7 of 21 (permalink) Old 07-01-2016, 04:26 PM
I'd say it's leaking into the motor at the slave. Fluid has to be going somewhere.
Aloha Tom likes this.
post #8 of 21 (permalink) Old 07-01-2016, 04:28 PM Thread Starter
L8ndeb's Avatar
Year: 1995
Model: Interstate
Hi Dennis,
I'll check it out tonight. Any tell tale signs?
Leyton at Reno
1995 GL1500I
L8ndeb is offline
post #9 of 21 (permalink) Old 07-01-2016, 04:34 PM
The lower fluid level in the reservoir suggests otherwise.
The engagement point near the grip suggests worn lever components.
Nothing you've said suggests that the clutch needs replacing or repair.
Ken Bergen is offline
post #10 of 21 (permalink) Old 07-01-2016, 04:47 PM Thread Starter
L8ndeb's Avatar
Year: 1995
Model: Interstate
Hi Ken, I do hate leaks, but nothing was appearing on the garage floor so I didn't think leak. I thought the fluid was going down due to wear on the clutch friction disks.
No, the lever is fine. No wobble of any sort.
I may have to renege on the engagement of the clutch statement. In actuality, the clutch, when you pull the handle, will disengage fine, but when releasing the handle, the clutch engages almost at the end at the handle stop.
Leyton at Reno
1995 GL1500I
L8ndeb is offline
GL1100 clutch replacement - Q about center clutch hub spinning freely aliensatemybuick Goldwing Technical Forum 7 11-13-2015 08:41 AM
1982 GL1100 Valve job and paint job saltydawg1967 Goldwing Technical Forum 17 07-02-2011 06:36 AM
GL1100 clutch cable too much free play - Clutch stuck? roehlerich Goldwing Technical Forum 10 10-22-2010 06:32 PM
GL1000 clutch dragging issue. wow, what a fun job to fix! supersonictoys Goldwing Technical Forum 4 08-10-2009 07:28 PM
Clutch Job jimjim Goldwing Technical Forum 14 02-19-2007 01:01 PM
