GL1000 restore. No matter how long it takes - Page 17 - Steve Saunders Goldwing Forums
 61Likes
post #161 of 320 (permalink) Old 10-14-2016, 12:45 AM
Cleaning gasoline tanks by electrolysis works very well and leaves it shiny clean. I've done it on a couple of bikes I was restoring, might still be some old postings about it on the website here. For an idea of how to do it see:
http://www.instructables.com/id/Elec...rcycle-Gas-Ta/
post #162 of 320 (permalink) Old 10-14-2016, 02:27 AM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
Originally Posted by wajulia View Post
I spent some time on youtube looking at ways to clean up my rusty fenders. I am just not in the right mindset to cover the expense of re-chroming them. But they certainly need it. Not only a loads of rust freckles, but blisters where the chrome has failed. The inside is fully covered in rust. See the pictures below. I would love to dip them in evaporust, but that would take gallons of the stuff and it is way to expensive for that.
So I came up with a plan. Combine white vinegar, Salt and flour. The vinegar is the acid, the salt provides free ions and the flour thickens it to a paste. Paint the paste onto the rust areas and rub with aluminum foil. I was amazed at how well it worked. The surface rust disappeared almost instantaneously. It did a pretty good job knocking down the solid rust inside the fender. Of course the blisters in the chrome are still there, but they are not rusty.
I clear coated the inside of the fenders. Spitting in the wind, but I needed to try something. I polished the outside of the fender, hoping the polishing compound inhibits the rust from reforming. Just have to keep on top of the polishing. Before and after picture below ,
I can always send the fenders for re-chroming sometime in the future if the feeling comes over me.
Keep an eye on ebay for new fenders. Every now and then someone parts out a bike from the southwest desert area. On my 450 I polished the outside and used Rustolem primer with chrome paint on the inside.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #163 of 320 (permalink) Old 10-14-2016, 09:12 AM
Get a 5 gallon bucket, fill it with water, dunk the fenders in it, and use electrolysis.
Rust B Gone w/o any work at all.
or get one of those cheapy plastic play pools for the kids from the Dollar Store...
about 6 bux....
fill that with water and dunk the whole fender(s) all at once and use electrolysis.
post #164 of 320 (permalink) Old 10-14-2016, 12:24 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Model: GL1800, GL1000
Wow, That looks like fun. I will do the rear fender using this process. then I might go back to the front and do it again if it works well, but now I will have to strip the clear coat.
wajulia is offline
post #165 of 320 (permalink) Old 10-15-2016, 01:37 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
The rear brakes!!
The differential next, It seems very smooth. Not going to open it up. Clean, Paint, polish install.
wajulia is offline
post #166 of 320 (permalink) Old 10-15-2016, 05:38 PM
Psst... It's not a differential just a right angle drive that's usually called the 'final drive'.
post #167 of 320 (permalink) Old 10-15-2016, 05:42 PM
Was waiting for some one to mention that
MaxThrust likes this.
post #168 of 320 (permalink) Old 10-17-2016, 10:16 AM
theRide's Avatar
Year: 1998
Model: Valkyrie
You may want to replace all the dash bulbs while it's apart. They usually have a similar lifespan and if a few went the others may follow.
I cheaped out on mine by getting a slightly lower wattage at a local pep boys and called it close enough.
theRide is offline
post #169 of 320 (permalink) Old 10-17-2016, 08:12 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Then Final drive it is. Thanks
The Final Drive is on the bike!!!!!
The blue tape is there to remind me that I need to fill it with oil and grease.
wajulia is offline
post #170 of 320 (permalink) Old 10-22-2016, 01:06 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Some of you may remember an earlier thread about rebuilding the breather. I ordered some breather filters from an older GM motor to use the filter material in it I would use to make a new breather filter for honda. Well after a month of waiting for them to arrive, I finally cancelled the order and ordered some more from someone else and they came.
In the month I waited, I put the engine back in the bike. Well taking the breather off with the engine in the bike is NEAR impossible. Spent hours taking it off and putting it back in.
I took the material out of two of them, and cut to fit int the screens in the breather. Later I did tie it all together with some copper wire before putting it all back together.
wajulia is offline
GL1000 Long Distance Riding Rodd General Motorcycle Discussion Forum 107 03-23-2015 06:36 PM
78 gl1000 running with no baffles in mufflers, any long term damage?? Sticky83 Goldwing Technical Forum 7 04-13-2012 04:25 PM
GL1000 1976 long handles mygoggie Goldwing Technical Forum 6 04-30-2011 08:48 AM
Time to get my GL1000 running (long winter project) MrShake Goldwing Technical Forum 13 12-09-2008 06:01 PM
gl1000 - long crank time when warm (stolen idea from another post) don_berry Goldwing Technical Forum 6 07-09-2006 08:54 PM
