GL1000 restore. No matter how long it takes - Page 23 - Steve Saunders Goldwing Forums
 61Likes
post #221 of 320 (permalink) Old 11-07-2016, 06:41 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Model: GL1800, GL1000
Originally Posted by Bellboy40 View Post
It has been quite a while since I owned my 1979 GL1000, but as I recall, the buzzer would sound between flashes of the blinkers.
The blinker relay only has two wires. One is the fused power, the other powers all the lights. So I took them both off and tapped them together like I was the relay turning on and off, When the lights were on the buzzer was off and vice Versa. I can't wait for the new relay to show up to see if it all works the way I think
flylow likes this.
wajulia is offline
post #222 of 320 (permalink) Old 11-10-2016, 10:17 AM Thread Starter
wajulia's Avatar
Year: 2004,1975
I got the blinker relay and it worked as planned. I have blinkers (Winkers as Honda calls them).
As I said, this is a really complicated circuit and it was all hacked up both in the front and rear of the bike. It took a lot to figure it all out again.
I tried a video to show how the blinker/beeper combination works. that sounds like one of those annoying backup horns, but I guess that is its purpose.
wajulia is offline
post #223 of 320 (permalink) Old 11-11-2016, 03:16 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
I was getting frustrated finding someone local to do the welding necessary to fix the stud on the exhaust. So I practiced and practiced and practiced some more.
I decided to drill out the original stud, look around a bit and decide what my next step was. When I started drilling out the stud I found that there was about 3/8" of material there. Not thin at all. It came to me that I might be able to tap it, so I did.
I then contemplated just putting a bolt in there instead of a stud, but a stud is what is supposed to be there. I screwed the bolt that I had in the hole, but I couldn't just leave it like that because it would turn if I tried to put a bolt on it.
Grow some balls! -- I put 4 small tacks on the bolt, cut off the top of the bolt, ground down the embarrassing welding, paint -- and wow
Brand new stud -- only the most observant far off future restorer will ever know.
Pretty happy with how that ended up. But I really need to invest in some welding classes. That skill opens up a hole new dimension of things one can tackle.
AZgl1800, flylow, theRide and 1 others like this.
wajulia is offline
post #224 of 320 (permalink) Old 11-11-2016, 05:51 PM
back in the '70s I worked for a pipeline company.
one of the welders there took pity on me and taught me how to drag a stick....
found out in a hurry if you don't do that everyday, you will never get good.
then he said, you know how to solder don't you??
"yep, I do" as I was the electronics technician there.....
he then said, "well, let me show you this thing, and he pulled out a Mig welder that was drinking Argon gas.... in about 5 minutes, he had me doing some of the purtiest stuff.... and he commented, "ya know, I could teach you to be a pipeliner in about two days"
post #225 of 320 (permalink) Old 11-12-2016, 11:49 AM Thread Starter
wajulia's Avatar
Year: 2004,1975
I put the exhaust on the bike today. How about those blue side covers. Those are the extras the PO gave me, just wanted to see how they looked. I might just rattle can them black just to fill in the holes. Or I might just wait until I paint all the panels.
wajulia is offline
post #226 of 320 (permalink) Old 11-12-2016, 11:49 AM Thread Starter
wajulia's Avatar
Year: 2004,1975
This post marks a bitter sweet milestone I ran out of parts!! I seem to be done. I guess I should change the name of the thread. I started in June 3, 2016 and put the last part on Nov 11, 2016. That is 161 days. That didn't take me that long. I was in a lucky position in my life that I could spend a little time every day.
I touched every bolt, nut, screw. Painted every part that should have been painted, cleaned and polished everything else. Spent lots of time putting the wiring harness back together. Replaced any missing or incorrect parts. I was pretty lucky, the bike was pretty complete and there were very few items that I couldn't refurbish and reuse.
I still have to paint the "Tins". I will either have someone do them over the winter or do them myself in the spring.
I also still have to start it and chase out the gremlins. I will start it during the thanksgiving break when my sons come home. I will record that and I promise to put it on the thread no matter what happens. IF I can get it out of my workshop. You may have noticed that I built it in my workshop. It has to go through two doors to get outside. My measurements say it should fit, I hope so, or I just built a motorcycle in a bottle.
If the weather holds, I will also do a few quick shakedown rides. I wish I timed this a little better so I could take the time to chase the gremlins out. At this point I will probably have to wait for spring to really put some seat time on the bike.
I have kept track of all the parts that I have bought. I will see if I can put them in a post so that people know what to expect if anyone wants to try this.
wajulia is offline
post #227 of 320 (permalink) Old 11-12-2016, 12:04 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
Nice work, 161 days is very good. The trick is to stay focused on the 'next' job and be ready for it. I'm interested in your cost accounting. I have a spread sheet for my GL1200I. I didn't do that on the 450 and I'm sure I went over $3,000. I will be watching for the first start.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #228 of 320 (permalink) Old 11-12-2016, 12:19 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
This is everything I bought for the restoration. I still have to paint the panels and deal with whatever items come up during the shakedown, so there will probably be more. But this gives anyone an idea of what the expense is to do a restoration on a bike like this. This is probably minimum. I was quite lucky that all the most of the parts were on the bike, and I did not have to make any major repairs to any of the primary components ie: engine, drive train etc.
I did not count any tools or consumables. Tools make you richer as a human being and cans of brake cleaner and paper towels are just the price of life. I don't think I counted all the paint cans I bought, so it is probably a little shy, but not much.
Ignoring the hours applied (there is no equation that would ever make that work out), I spent $850 for the bike, $1,100 on the restoration. I think that means that I SHOULD be able to make a few dollars if I sold it. At least break even. I didn't do it for profit, I did it because I am addicted to cleaning, repairing, painting, repeat. But it feeds the habit ( I have no plans to sell it , so for now the habit just keeps draining the wallet)
What's next?? I am thinking of a CB750. I like those bikes, but I bet I will never be able to find one for $850
AZgl1800 likes this.
wajulia is offline
post #229 of 320 (permalink) Old 11-12-2016, 12:38 PM
I'm looking forward to when you fire that joker up and we have to help diagnose carb problems
Not that I'm knocking it's quality, but I see that some o-rings and a few screws and washers for your carbs were easily the biggest single expenditure for your bike, even without the $30 video, so I'll say it again. Carb kits are way overpriced for what they are.
spiralout is offline
post #230 of 320 (permalink) Old 11-12-2016, 01:19 PM
Very satisfying thing to do. I did a total rebuild on a 1980 GL1100 a few years ago. Took it down to bare frame, replaced, repaired, and painted each part that needed it. All screws and bolts cleaned and buffed, all chrome and aluminum polished. Took some scrounging and Ebay to get all the parts needed. Carb rebuild and adjusting was interesting. Anyway in the end I ended up with what looked and ran like a new bike. I made some money selling it but not much profit if you consider time spent on the bike. I wanted to do a chassis up restoration on a model A but I couldn't really afford that. The project on the 1100 was very satisfying to me as I'm sure it is with you. During the ten years I had my shop in Tacoma I refurbished about eight 'oldwings'. My favorite of the bunch was a 1980 Standard Goldwing. That bike was downright fun to ride and without the fairing weighing it down a very nice performing motorcycle. Not a single rattle either. I sure wish I'd kept that one but I made $2000 on it for minimal work and money does have a way of changing one's mind.
GL1000 Long Distance Riding Rodd General Motorcycle Discussion Forum 107 03-23-2015 06:36 PM
78 gl1000 running with no baffles in mufflers, any long term damage?? Sticky83 Goldwing Technical Forum 7 04-13-2012 04:25 PM
GL1000 1976 long handles mygoggie Goldwing Technical Forum 6 04-30-2011 08:48 AM
Time to get my GL1000 running (long winter project) MrShake Goldwing Technical Forum 13 12-09-2008 06:01 PM
gl1000 - long crank time when warm (stolen idea from another post) don_berry Goldwing Technical Forum 6 07-09-2006 08:54 PM
