GL1000 restore. No matter how long it takes - Page 27 - Steve Saunders Goldwing Forums
 61Likes
post #261 of 320 (permalink) Old 11-27-2016, 05:50 PM
Pure Texas's Avatar
Make: Goldwing
ok.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is online now
post #262 of 320 (permalink) Old 11-27-2016, 06:06 PM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
Try cleaning and lubing the throttle cable to see if it helps your return issue. Or disconnect them from the bell crank at the back and see how it responds manually. If it's in your cables, an old spark plug boot fits nicely over the cables at the top and makes a reservoir for your favourite cleaner. Place a rag under the cables at the carbs and work them back and forth until they run freely with the lubricant/ cleaner all the way through. Avoid anything with brake cleaner/acetone for the sake of your paint. It could be in the throttle sleeve at the grips too.
Ekvh1 is online now
post #263 of 320 (permalink) Old 11-27-2016, 06:17 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Model: GL1800, GL1000
Originally Posted by Pure Texas View Post
Adjust the clutch so it catches about just a little over halfway out .
What adjustment is in the clutch, the adjustment at the lever itself? That will change where the clutch engages, I will try to get to it tomorrow, because I don't like it so far out
wajulia is offline
post #264 of 320 (permalink) Old 11-27-2016, 06:26 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Originally Posted by spiralout View Post
It's idling too fast to get an accurate synch, too. Adjust it down to about 1k.
Ok. Having some problems getting the idle low enough since it tends to wander. Adjust it to about 1k and it wanders down to low. But I will, adjust a little, lower the idle, readjust. Patience!
No one commented on leaning out the idle. I will experiment a little tomorrow.
wajulia is offline
post #265 of 320 (permalink) Old 11-27-2016, 06:31 PM
Originally Posted by wajulia View Post
...but it might just be me getting used to the clutch which seems to engage way out in its throw. So I tend to put to much gas into the engine before the clutch engages.
You should only have between about 1/4-1/2" of play at the end of the lever.
There are three adjustments for the clutch. The adjuster screw behind the lifter cover, the lower cable adjuster and the upper cable adjuster by the lever.
spiralout is offline
post #266 of 320 (permalink) Old 11-27-2016, 06:32 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
The pull cable is brand new, so I shouldn't need to clean it. I will remove it to see if it comes back the way I expect. I could also be the sleeve as you mention. The Randakk video for the carb rebuild warns that if the cables are routed wrong they will bind. I will disconnect it first as you recommend
wajulia is offline
post #267 of 320 (permalink) Old 11-27-2016, 06:45 PM
Leaning it out with the mixture screws probably won't help. I suspect it may be flooding in 1 or more of the carbs or in the intake plenum or possibly it is too lean.
post #268 of 320 (permalink) Old 11-27-2016, 06:46 PM
To me, it didn't look like you had the sync balanced correctly and that can cause erattic idle.
post #269 of 320 (permalink) Old 11-27-2016, 08:19 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Can you tell me why you say that. The pattern on the manometer not tight enough?
wajulia is offline
post #270 of 320 (permalink) Old 11-27-2016, 08:27 PM
Exactly. And those air bubbles have to be gotten out so the columns can give you a good reading.
GL1000 Long Distance Riding Rodd General Motorcycle Discussion Forum 107 03-23-2015 06:36 PM
78 gl1000 running with no baffles in mufflers, any long term damage?? Sticky83 Goldwing Technical Forum 7 04-13-2012 04:25 PM
GL1000 1976 long handles mygoggie Goldwing Technical Forum 6 04-30-2011 08:48 AM
Time to get my GL1000 running (long winter project) MrShake Goldwing Technical Forum 13 12-09-2008 06:01 PM
gl1000 - long crank time when warm (stolen idea from another post) don_berry Goldwing Technical Forum 6 07-09-2006 08:54 PM
