GL1000 restore. No matter how long it takes - Page 6 - Steve Saunders Goldwing Forums
 61Likes
post #51 of 320 (permalink) Old 08-02-2016, 08:08 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Model: GL1800, GL1000
I noticed that the internal bearings have alternating large balls and small balls. The small balls seem to be about the size of the FOD I found
I looked at all the bearings and they all seem to be tight and smooth. Can't see any little balls missing, but I think there is a cover over the bearings so you can't see them anyway. Any suggestions would be great
wajulia is offline
post #52 of 320 (permalink) Old 08-02-2016, 08:14 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Thanks for all the help. I will look at Everett powersports
I plan to go through everything, especially both the oil pumps before I put it back in. Take my time, make sure everything is right and put it back together carefully.
Originally Posted by rocks View Post
Did you figure out where that FOD come from?
I bought my rings from everett_powersports on ebay. He sold out. I got STD size.
While you are down there, replace main chain tensioner with GL1200. Those have spring loaded, and will quiet the noise on idle. Also you will have to modify the trough
Check out John : http://www.wingovations.com/fitting-...ain/4584942275
Make sure the main chain is still reusable.
Rebuild the scavenger pump. Again, John explained that too.
This is how to select the main and con-rod bearings
http://www.wingovations.com/choosing...ngs/4588152247
He can hook you up with some piston rings as well.
wajulia is offline
post #53 of 320 (permalink) Old 08-02-2016, 08:30 PM
The con rod bearings are now going to be available new, read this:
https://www.goldwingfacts.com/forums/...n-waiting.html
WingGoVations is having them manufactured in Germany
NASR 12 in Galena, IL
post #54 of 320 (permalink) Old 08-02-2016, 08:59 PM
What you're calling small balls is the riveting on the beating cage used to keep the balls evenly spaced.
Ken Bergen is online now
post #55 of 320 (permalink) Old 08-04-2016, 08:08 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Measured the main bearing clearance with plastiguage Two were .0015 and the other was .001. Limit is .003. The motor keeps looking in good shape, So I am going to stop measuring and put it back together.
I deglazed the cylinders. Very pleased on how they came out. Ordered new rings from eBay
Both halves have been cleaned and painted, see the pic. All ready for the parts to be put back on. I will start tomorrow, Wanted the paint to cure overnight
Schneidly likes this.
wajulia is offline
post #56 of 320 (permalink) Old 08-04-2016, 08:22 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
I was putting the heads back together tonight, While torquing the rocker frame back on (220 in lb) I started feeling a few of the bolts stretch. One of them failed, I was lucky enough to stop before it broke so I didn't have to fish it out of the whole. I took it out in one piece. Luckily I can still buy them from Honda, so I am going to replace all 12
Any thoughts about the torque on those bolts, 220 in lb. (18 ft lb ) sure doesn't seem like enough to stretch those bolts.
If you look real close you can see the threads separating at the very top of the thread
wajulia is offline
post #57 of 320 (permalink) Old 08-04-2016, 08:29 PM
rocks's Avatar
Year: 1977
Model: GL1000
Nice painting job. Did you do it yourself? What kind spray did you use?
You have to oil the threads and the bottom of the heads.
rocks is offline
post #58 of 320 (permalink) Old 08-05-2016, 06:33 AM Thread Starter
wajulia's Avatar
Year: 2004,1975
Duplicolor engine enamel Aluminum DE1615
I had moly on the threads when I put them in.
wajulia is offline
post #59 of 320 (permalink) Old 08-05-2016, 07:57 AM
Old Fogey's Avatar
Model: as in the signature, but subject to change!
No, no, the Moly greasing only applies to the head bolts. The rocker holder bolts go in dry. That is why you stretched the bolt. With them greased you would have to tighten WAY too much to get to that torque reading.
wingformation on
1976 GL1000 \'The Swan\' - from an ugly ducking..
1979 GL1000 \'Black Bess\'- original.
Old Fogey is offline
post #60 of 320 (permalink) Old 08-05-2016, 06:30 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Broken bolts suck!
I started putting everything back together again. Cleaned checked and put back the two oil pumps. Broke another stud on the main oil pump. Lucky again, the whole bolt came out in one piece. No fishing the broken piece out This time with my torque wrench set to 150 inch pounds. What? Ok. Time to back away and figure out what is going on. My 40 year old torque wrench is failing me. I took it all apart, hardened grease and sticky parts, cleaned it and compared it to my foot pound wrench, They both read the same at 10 and 20 foot pounds. Tried it on the pump again and it felt MUCH better.
So I had to order some more studs for the oil pump. I put the lower transmission back in and the shifter forks.
wajulia is offline
GL1000 Long Distance Riding Rodd General Motorcycle Discussion Forum 107 03-23-2015 06:36 PM
78 gl1000 running with no baffles in mufflers, any long term damage?? Sticky83 Goldwing Technical Forum 7 04-13-2012 04:25 PM
GL1000 1976 long handles mygoggie Goldwing Technical Forum 6 04-30-2011 08:48 AM
Time to get my GL1000 running (long winter project) MrShake Goldwing Technical Forum 13 12-09-2008 06:01 PM
gl1000 - long crank time when warm (stolen idea from another post) don_berry Goldwing Technical Forum 6 07-09-2006 08:54 PM
