GL1000 restore. No matter how long it takes - Page 7 - Steve Saunders Goldwing Forums
 61Likes
post #61 of 320 (permalink) Old 08-05-2016, 06:40 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Model: GL1800, GL1000
I decided to put in a 1200 spring chain tensioner. Ordered one from eBay. So now I am waiting for the oil pump studs and the spring chain tensioner. I know that I need to modify the chain shroud, any suggestions would be great
While I am waiting for the parts, I decided to clean and paint something else. I picked the front cover, oil filter and water pump. Inspecting the water pump, I realize that it takes two hands to turn the pump. Wow. So earlier I discussed that I thought the bike had cooling issues. One head gasket had been replaced, there was no thermostat, it really seems that the PO was struggling with overheating issues. I find a serious issue in the water pump. Try to free up the water pump, the vanes crumble, No problem, I will buy another. WOW those are a little pricey! But the water pump is a pretty important part. If I get the cooling under control it will be worthwhile.
wajulia is offline
post #62 of 320 (permalink) Old 08-05-2016, 06:52 PM
did you see the 'note' about NOT using moly on those bolts?
that is a real no no...
What is the Forum Index?
Download it here:
post #63 of 320 (permalink) Old 08-05-2016, 07:06 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Yes. I heard it. As it is said, education is expensive! I really appreciate that you guys keep the cost to a minimum.
Won't do that again, but YES on the moly for the head bolts?
wajulia is offline
post #64 of 320 (permalink) Old 08-05-2016, 07:08 PM
Originally Posted by wajulia View Post
This time with my torque wrench set to 150 inch pounds. What? Ok. Time to back away and figure out what is going on. My 40 year old torque wrench is failing me. I took it all apart, hardened grease and sticky parts, cleaned it and compared it to my foot pound wrench, They both read the same at 10 and 20 foot pounds. Tried it on the pump again and it felt MUCH better.
Most manufacturers recommend checking the calibration of their click type torque wrenches yearly.
For home mechanics (Shade Tree) I would recommend a beam type torque wrench.
Ken Bergen is online now
post #65 of 320 (permalink) Old 08-05-2016, 07:11 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
I needed a success, and I saw the timing hole cover and said, "I can polish that ". Well that felt good, instant gratification polishing aluminum!
wajulia is offline
post #66 of 320 (permalink) Old 08-06-2016, 01:18 PM
rocks's Avatar
Year: 1977
Model: GL1000
http://www.wingovations.com/fitting-...ain/4584942275
rocks is offline
post #67 of 320 (permalink) Old 08-06-2016, 05:22 PM Thread Starter
wajulia's Avatar
Year: 2004,1975
Waiting for parts so I took some time to. --- clean , paint, assemble!
Finished the front cover. Quite a PIA. Lots of nooks and crannies. As i was cleaning it I realized that the existing paint was flaking off. I had to take all the paint off from all those nooks and crannies But it is done, waiting for the new water pump
wajulia is offline
post #68 of 320 (permalink) Old 08-06-2016, 08:48 PM
it sure is going to be a purty thang when you get finished.
Download it here:
post #69 of 320 (permalink) Old 08-07-2016, 01:24 AM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
Wajulia, nice work. I will be going down the same path with my 1100. One thing I have learned, you cannot just pretty up a few parts. Once you start you have to do them all.
Do you have any comments on splitting the case halfs? How did you break the seal? Did you remove the alternator rotor and clutch? THX- JimP
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #70 of 320 (permalink) Old 08-07-2016, 02:32 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
You have or will need to clean each of those bolt holes so the moly is out.
Right!
In the beginning I would have said soak the cylinders.........
What you are doing is better you needed new rings.
Them water pumps only last 60,000 miles. So replace the pump anytime your unsure.
JeffMayfield is offline
GL1000 Long Distance Riding Rodd General Motorcycle Discussion Forum 107 03-23-2015 06:36 PM
78 gl1000 running with no baffles in mufflers, any long term damage?? Sticky83 Goldwing Technical Forum 7 04-13-2012 04:25 PM
GL1000 1976 long handles mygoggie Goldwing Technical Forum 6 04-30-2011 08:48 AM
Time to get my GL1000 running (long winter project) MrShake Goldwing Technical Forum 13 12-09-2008 06:01 PM
gl1000 - long crank time when warm (stolen idea from another post) don_berry Goldwing Technical Forum 6 07-09-2006 08:54 PM
