84 gl1200 - Page 10 - Steve Saunders Goldwing Forums
 5Likes
post #91 of 188 (permalink) Old 08-05-2016, 01:38 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I'd clean the slave while you have it in hand and replace the rubber (o-rings) if they are in need of changing and I'd bet they are.
Bike...and Dennis likes this.
JeffMayfield is offline
post #92 of 188 (permalink) Old 08-05-2016, 10:56 AM
And definitely replace the seal in the rear cover.
post #93 of 188 (permalink) Old 08-05-2016, 12:14 PM Thread Starter
big PIA
MysticFour's Avatar
are those things I might find locally?
raining off and on here today so not sure I am starting on it now as I have to do it in driveway
MysticFour is offline
post #94 of 188 (permalink) Old 08-05-2016, 12:59 PM
Probably not. Call your local dealer.
You want #s 9, 14 & 15. Maybe #11 too, but inspect it first.
http://www.westernhonda.com/fiche_se...84&fveh=132500
Check the entire line for leaks as well.
post #95 of 188 (permalink) Old 08-05-2016, 03:58 PM Thread Starter
big PIA
MysticFour's Avatar
lucky for me I have 2 clutch slaves.
I am hating the cruise control crap, making it hard to get to everything around the radiator area. Just removing it all, not like I will need it. Control look like crap and buttons cracked, probably doesn't work so I am just going to pitch it unless somebody wants it.
Did start pulling the stuff apart to get engine out but can I get the clutch slave on and off with engine in bike? I want to put engine back in as soon as I get the rest of the parts on it, don't want to wait on slave parts to install if I can help it
post #96 of 188 (permalink) Old 08-05-2016, 04:16 PM
Yes, but many here have been unable to replace the seal in the clutch case with the motor in. So I really advise you do that with the motor out.
post #97 of 188 (permalink) Old 08-05-2016, 07:08 PM Thread Starter
big PIA
MysticFour's Avatar
well done working on it for the night, motor almost ready to come out4 bolts to take loose and getting something under motor to help pull it out so I can actually work on it
post #98 of 188 (permalink) Old 08-05-2016, 11:49 PM
Just Winging It
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Look for lose/worn linkage on the carburetors.
I believe many those after market cruise controls have caused slack in the linkage resulting in carbs that go out of sync when you turn the throttle.
The low speed hesitation has had many a man cleaning and recleaning the carbs when the problem was the after market cruise control had for many years pulled the linkage from the left side instead of using the place the throttle cables do. Any twisting of the throttle done by the operator while using the cruise or not causes undue wear on the linkage that is unobtainium.
Just something to keep in mind along the way.
I found play between the right and left banks on the bike that had the added cruise and low speed hesitation.
post #99 of 188 (permalink) Old 08-06-2016, 01:13 PM Thread Starter
big PIA
MysticFour's Avatar
Went to remove cap from clutch master cylinder and 1 of the screws is stripped out and rounded, how can I get this screw out?
post #100 of 188 (permalink) Old 08-06-2016, 01:47 PM
That's pretty common. You could drill the head off the screw. Make sure you leave enough of the shank to get some pliers on it.
Also, I wonder if you could fill the screw head with JB Weld and then cut a slot on that.
Foot peg swap-ability between years GL1100/GL1200/GL1200 esturdivant Goldwing Technical Forum 4 05-04-2014 06:45 AM
Gl1200 oil seal on gl1200 shelbylen Goldwing Technical Forum 4 11-22-2013 07:18 PM
will carbs from 86 GL1200 fit my 84 GL1200 blu boy Goldwing Technical Forum 5 03-09-2011 06:42 PM
GL1200 Aspencade to GL1200 Naked Conversation? GoodSpeed General Motorcycle Discussion Forum 18 06-02-2008 04:09 PM
