Poor Boy finally done - Page 2 - Steve Saunders Goldwing Forums
post #11 of 14 (permalink) Old 07-20-2016, 12:42 AM
Originally Posted by Mike Myers View Post
so... which way is the fan turning now? as admired from the front of the bike? clockwise?
I don't know for sure but you are correct. The fan should be turning clockwise to push air. I would also seal up the breaker from the weather or move it to a sheltered place. At a minimum mount it black side down and metal up. It could fill with water like that.
redwing52 is online now
post #12 of 14 (permalink) Old 07-23-2016, 07:04 AM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
Well guys I did find out that the OEM fan after reversed worked well but it was to tall, So I went to local auto part store and bought a 10" low profile fan made by Hayden and mounted it
it the same spot were I had the OEM fan and that works perfect, 2 5/8" high.
Patriot Guard Rider #144639
McFirefighter is offline
post #13 of 14 (permalink) Old 07-23-2016, 10:13 AM
Are you saying you mounted it in the stock location, behind the radiator?
post #14 of 14 (permalink) Old 07-23-2016, 12:26 PM
nope, he did not.
he put the new fan, in the same location "in front of the radiator" where he had the OEM fan installed.
now that he has a fan that is purpose built to "push air", that radiator will work a LOT better.
The OEM impeller turned around and running backwards, will NOT push air worth a damn. the curve is wrong. The impeller has to come off the motor shaft, reverse the impeller, and put it back on the motor.
That way, with the motor running in Reverse rotation, the impeller will be turning precisely like Honda intended for it to be.
poor boy kit harry anderson Goldwing Technical Forum 6 10-02-2013 08:10 AM
poor boy on ltd/done cabinguy Goldwing Technical Forum 11 08-06-2012 06:39 PM
poor boy converson monsterman Goldwing Technical Forum 2 07-04-2010 07:03 PM
Poor boy kit tcehjes Goldwing Technical Forum 18 04-17-2010 11:14 PM
poor boy krazy al Goldwing Technical Forum 2 10-02-2009 08:00 AM
