Bad ignition switch? 92 GL1500. - Page 3 - Steve Saunders Goldwing Forums
post #21 of 31 (permalink) Old 07-26-2016, 02:44 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
DBohrer,
I see, but when we have power on the "hot in on" end of the relay that voltage will go through the circuit as if the ignition key is turned on.
And this will cause the lights to come on.
Erdeniz Umman is offline
post #22 of 31 (permalink) Old 07-26-2016, 03:39 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Yep, that is true. There would be power to the head fuse, starter/reverse switch, dimmer switch which would activate the head light relays.
Good catch...........!!
I should know by now not to question anything you say as you are always right. I don't know too many folks like that...!!
Originally Posted by Erdeniz Umman View Post
DBohrer,
Erdeniz Umman likes this.
DBohrer is offline
post #23 of 31 (permalink) Old 07-26-2016, 03:57 PM
Thanks a lot to hear such beautiful words from a guru.
post #24 of 31 (permalink) Old 07-26-2016, 04:57 PM
Alright, I was with Dave, then I wasn't, now I am just confused. I tried to find a path for the power to flow from the #3 to the dimmer power and it seems the diode should block the path. I'm not doubting there is a path but with all the spaghetti I can't find it. Now I have a headache and quit. Help me please.
redwing52 is online now
post #25 of 31 (permalink) Old 07-26-2016, 05:40 PM
DBohrer's Avatar
Year: 1967
Bad Ignition Switch
Relay # 3 always has "load" voltage (even with the ignition OFF).
If the relay # 3 was stuck in the closed position (or if the load and trigger pins were shorted together), there would be voltage on the black trigger wire.
If the Relay # 3 (black trigger wire) has voltage, it will go to the # 12 head relay 5-amp fuse, then from there to the starter/reverse switch (brown/red wire, connector then a brown/white wire), then to the dimmer switch (blue/white wire). The dimmer switch will activate the head light relays # 4 and # 8 depending on the setting.
No diode involved..........!
QUOTE=redwing52;4766201]Alright, I was with Dave, then I wasn't, now I am just confused. I tried to find a path for the power to flow from the #3 to the dimmer power and it seems the diode should block the path. I'm not doubting there is a path but with all the spaghetti I can't find it. Now I have a headache and quit. Help me please.[/QUOTE]
DBohrer is offline
post #26 of 31 (permalink) Old 07-26-2016, 05:51 PM
[QUOTE=DBohrer;4766273]Relay
If the point set was closed (or shorted) why would the black wire be hot. Am I missing something? Wrong schematic?
post #27 of 31 (permalink) Old 07-26-2016, 05:53 PM
Must have changed between 91 and 94. The 91 book shows what you mean. I get it! Thanks Dave. Gotta go rest my head.
post #28 of 31 (permalink) Old 07-26-2016, 05:59 PM
Bluewaterhooker0's Avatar
Make: Goldwing SE
Model: '97 GL 1500SE
Wow. I'm impressed by the 'smarts' contained in these pages. I'm pretty darn good with air conditioning electric and controls, and not bad with most other things. But, these bikes are a real challenge. I guess it doesn't hurt to be working on them a lot, and for a long period of time. You Da Men ! (That's plural, as in both of you)
Thomas Paine December, 1776
Bluewaterhooker0 is offline
post #29 of 31 (permalink) Old 07-26-2016, 06:00 PM
DBohrer's Avatar
Year: 1967
If the "load" pin and "trigger pin" in the relay was shorted together, the black trigger wire (connected to the trigger pin) would have voltage. This is the same black wire that comes from the ignition switch when turned ON. Except in this case, the ignition switch would be OFF but that black wire would still have voltage (from the load pin). Remember the "load" pin is always hot.....!
[quote=redwing52;4766305]
Relay
DBohrer is offline
post #30 of 31 (permalink) Old 07-26-2016, 06:10 PM
DBohrer's Avatar
Year: 1967
My 1996 and 1999 manual shows as I described. I think your 1994 manual should show the same. Is it the Honda manual....??
DBohrer is offline
GL1200 1984 bad Ignition switch robertbynum Goldwing Technical Forum 23 12-19-2012 08:16 PM
GL1500 Ignition switch Square Shooter Goldwing Technical Forum 7 07-05-2012 12:05 PM
Ignition switch removal, GL1500 dan3071 Goldwing Technical Forum 5 04-13-2012 05:42 PM
no dash lights...bad ignition switch? JAinPA Goldwing Technical Forum 7 06-13-2006 08:02 PM
Bad Ignition Switch Wingin It Gene Goldwing Technical Forum 5 07-25-2005 12:11 PM
