Brake Issue - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 07-27-2016, 07:35 PM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
Brake Issue
Good evening I replaced my fork seals on my GL 1200 I got everthing put back together but now when I put my bakes on foot break and hand break I am getting a noise like the tire is rubbing something and the bike is pulling to the left. I took the breaks back apart and cleaned everything on both sides, the bike is still making the noise and pulling to the left. It was not doing this before I replaced the seals. What have I got wrong? I don't know what else to do.
Patriot Guard Rider #144639
McFirefighter is offline
post #2 of 7 (permalink) Old 07-27-2016, 08:01 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Did you remember the axle spacer?
busdriver is offline
post #3 of 7 (permalink) Old 07-27-2016, 08:15 PM Thread Starter
Year: 1990
Model: Aspencade
Axle spacer ? I replaced everything back the way it was when I took it apart. Dont know what axle spacer your referring to.
post #4 of 7 (permalink) Old 07-27-2016, 09:09 PM
Did you remove the rotors from the wheel?
Did you check to see if the pad springs are seated right?
post #5 of 7 (permalink) Old 07-27-2016, 10:46 PM
Are the forks installed (bottomed out) properly? If one is too high or low the tire could rub and pull when braking. Do you have the fork brace on with the front facing forward? Might sound dumb but I have put the pads in facing the wrong way on cars. It makes a hell of a noise. The metal part has to face away from the rotor.
I think Busdriver is thinking rear brakes and axle????????
redwing52 is online now
post #6 of 7 (permalink) Old 07-28-2016, 05:42 AM Thread Starter
Year: 1990
Model: Aspencade
I did not remove the rotors from the wheels, and there was not any springs on the pads. And when the forks are put back together there is no why to get one higher then the other
I didnt remove the upper fork from frame. So I dont know how one could be higher then the other. I put everything back together like it was when I took it apart. I have
know idea what is different. I know that the left brake is the front break and the right one works off the foot break. Are both of them suppose to work off the foot break?.
post #7 of 7 (permalink) Old 07-28-2016, 05:14 PM
Year: 94
Model: 1500 SE
No- the foot pedal is intended to work the rear and 1 front,
which side front varies with generation/engine,,yours is right side, 1500s its left side
While you can easily stop the Wing with 1 finger on front brake, its good to be in the habit of using rear for more power and stability,
then use front only as you come to a stop.
That leaves both feet ready to plant on the ground for safety.
Tip- to prevent unexpected tip-over while stopped, always stop and start off with the front wheel pointed straight ahead.
If anything bad happens in front of you- or comes from the side...and you have to grab the brakes, the bike wont succumb
to the physics of gravity and tire angle
Happens even to very experienced Wing riders- we have video proof on here!
Aloha Tom is offline
82 GL110 Brake Issue FirstCavArmyVet General Motorcycle Discussion Forum 3 09-21-2012 06:15 PM
1800 Brake Issue JB Wolfe Goldwing Technical Forum 22 08-23-2012 07:46 AM
GL1500 Brake Issue... Payneful13 Goldwing Technical Forum 12 02-13-2011 02:41 AM
Front Brake issue TimMitchell Goldwing Technical Forum 11 04-16-2010 12:43 AM
Rear Brake Issue blueroy81 Goldwing Technical Forum 7 03-19-2007 11:29 AM
